Alexf1 wrote: ↑06 Aug 2021, 20:45It certainly looks like '20 to '21 the rear has gone from weakest to strongest downforce side of the car. With the front relatively unchanged that means they just had to take rear wing off to balance it out. So on front limited tracks like Barcelona, France and Hungary going low downforce on the rear wing was their only choice. The better/stronger rear tyres contributed to even more understeer I think. The new rears don't have to be a negative factor as long as the track is not high downforce front limited.SmallSoldier wrote: ↑31 Jul 2021, 15:42That would be my guess… They couldn’t dial out the understeer, therefore if you can’t add more front downforce, the only way to deal with the understeer is to take rear wing out
If they have more rear downforce than they did last year, they would be quicker than last year, but the cars are well off the pace of last year so I can't see how anyone can have more rear end grip than last year.diffuser wrote: ↑09 Aug 2021, 22:57Alexf1 wrote: ↑06 Aug 2021, 20:45It certainly looks like '20 to '21 the rear has gone from weakest to strongest downforce side of the car. With the front relatively unchanged that means they just had to take rear wing off to balance it out. So on front limited tracks like Barcelona, France and Hungary going low downforce on the rear wing was their only choice. The better/stronger rear tyres contributed to even more understeer I think. The new rears don't have to be a negative factor as long as the track is not high downforce front limited.SmallSoldier wrote: ↑31 Jul 2021, 15:42
Impressive that this year's car has more rear DF than last when the regulation changes only effected the rear. You have to think they've surpassed the rear DF they had available last year.
https://www.motorsport.com/f1/news/tech ... s/6645162/Tech analysis: Red Bull's latest F1 brake duct tweaks
By: Matt Somerfield Co-author: Giorgio Piola
Aug 10, 2021, 10:15 AM
Red Bull was extremely busy during the opening phase of 2021, bringing performance updates at nearly every Formula 1 grand prix.
Yet they have to cut it back(run lower DF rear wings) cause the front can't keep up.NathanOlder wrote: ↑10 Aug 2021, 13:39If they have more rear downforce than they did last year, they would be quicker than last year, but the cars are well off the pace of last year so I can't see how anyone can have more rear end grip than last year.diffuser wrote: ↑09 Aug 2021, 22:57Alexf1 wrote: ↑06 Aug 2021, 20:45
But is about balance, isn’t it (in particular with how it changes with speed), when the whole grid is covered by a time difference that is so small 0.05% of a performance change can be important (very important-maybe the difference between Q1&Q3!!!).diffuser wrote: ↑10 Aug 2021, 14:45Yet they have to cut it back(run lower DF rear wings) cause the front can't keep up.NathanOlder wrote: ↑10 Aug 2021, 13:39If they have more rear downforce than they did last year, they would be quicker than last year, but the cars are well off the pace of last year so I can't see how anyone can have more rear end grip than last year.
Perhaps it's a matter of getting more seat time with them. I feel that finishing the race with a wounded car, at least let Verstappen get a feel for the tires, and at least some useful data for the engineers in how they can adapt the setup going forward.Stu wrote: ↑10 Aug 2021, 18:42But is about balance, isn’t it (in particular with how it changes with speed), when the whole grid is covered by a time difference that is so small 0.05% of a performance change can be important (very important-maybe the difference between Q1&Q3!!!).diffuser wrote: ↑10 Aug 2021, 14:45Yet they have to cut it back(run lower DF rear wings) cause the front can't keep up.NathanOlder wrote: ↑10 Aug 2021, 13:39
I think that the biggest game-changer that we will see this year is with the rear tyres (and how the stiffer sidewall behaves), it appears to suit the M******* more than the Red Bull, others appear to very neutral.
Does anyone know the following: with equal rear wing setting and same hp, how many km/h would a high rake car be slower than a low rake car at the end of a medium length straight like Austria or Barcelona? This year RB16B and W12 always seem to have different rear wing DF levels to one another so it's difficult to compare.NathanOlder wrote: ↑10 Aug 2021, 18:35Redbull don't appear to be able to run much rear wing as the drag is too high and they end up too slow on the straights.
I dont think there is ever too much rear downforce in f1. too much drag certainly, but there's no way they have trimmed the rear wing because of too much rear grip.
The spring setting is a part of the setup. I have not seen a high rake car not burn off the rake fairly quickly. Generally you want full rake at sub 150kph speeds. Basical so you can go full throttle sooner. Once you get to a full throttle speed the rake starts to drop off fairly quickly. So the answer to the previous person's question..at equal rear wing DF levels ...the high rake car at high speed will have less rear wing, less DF and therefore less drag at top speed.godlameroso wrote: ↑01 Sep 2021, 01:35From what I see, it depends. If you have a high rake car that squats at speed, then the drag at speed would change, if you maintain that rake at speed, then I would imagine it would change the drag as well, how I have no clue.
