Facts Only wrote:PlatinumZealot wrote:Never mind. The man is holding the turbo with the outlet facing him. The part facing the camera is where the bearing housing connects.
Its the other way round mate, that's the outlet facing us. You can see where the scroll enters at the back where the edge of the wheel is and the v-band detail for mating the tailpipe on the outlet edge closest to us.
I see the V-band flange - easy to assume it is for the down pipe like a normal performance turbo.. but..
I know I am defying what seems obvious. It is hard to tell because the housing is so unusual but I expected a radiused edge going into the diffuser section. Instead, coming from the circumferential nozzle closer to us there is what seems to be a sharp edge... That means If you put in the turbine wheel there is almost a fully open path to the exit... that is just strange if you ask me. Also the exducer of the wheel would have to be huuuuge!! Like 100mm perhaps? Use that Japanese man's middle finger as a gauge, then measure the length of your middle finger..so >> 100mm exducer.. I know there is MGUH-H to make up for turbo lag but that is some serious tail pipe!
Call me crazy but my gut feeling is that the central cartridge connects with the V-band then the other side is where the diffuser is fixed in to place...
I know the heat shield for the central section needs a seat.. but I am assuming that this heat shield is a very special design...
Let's see..
