ringo wrote:
One thing though i don't think all the fancy energy saving stuff will be in F1 in 2013.
I think a simple KERS unit, L4 twin turbo, direct injection and that about it for the engine.
It has to be manageable for a reduced team size and lower costs. Which is the direction F1 is going. HERS doesn't add much more to entertainment value so that's not likely.
yepp, exactly that what i also think.
formula1 today is not only a sport, its a big business.
so they simply search for the best balance between development costs and efficiency. a "simple" twincharged 1.6L L4 may do here the best job. everything beyond that would not match the balance between costs and result. we also discussed far and long the very questionable use of other systems in an engine with quick load changes.
the normal spectator does not see and understand the technology, so they do not want to spend tremndenous money in the engine- it somply has to do the job.
i bet ,like already said, that they will hard regulate the engine up to bore and stroke dimensions and the turbo by itself , no team shall spend big money in gaining an advance further developing its engine. all teams should stay equal and FIA does not want "surprises" from one season to another regarding power output and laptimes.
they learned from the past and the tricky engineers with damaging development costs. they learned from seasons like 2002 when one team had such an advance that it was clear that ferrari would win.
well, very very sad from the sports view. in 2013 we will see a formula that with minimum effort will try to reach maximum financial result and an formula in which every team will use the same hard regulated technology without any chance of introducing something new by itself.
but this has been already discussed here...
