Here’s a really useful post from the Monza 2018 Thread.
yelistener wrote: ↑18 Sep 2018, 10:24
Did a little video about the ERS and Overtake button at work, from Monza onboard.
Gasly pressed the overtake button for a better corner exit acceleration. But it can only work for a few seconds, so after that it was back to auto ERS deployment based on the setting. It's also very clear to see the battery bar went down on straights and went back up after braking through corners, which is how MGU-K works.
I enhanced the audio a tiny bit so it's a little easier to hear the sound of the electric boost. The few seconds where Gasly pressed the overtake button is obviously the sound of the maximum ERS boost, but the electric boost was working on all straights during that lap, just not in that extremely-consuming overtaking mode.
https://www.youtube.com/watch?v=xmEZGKfo50o
It was made to illustrate the use of the overtake button but it also illustrates the use of ICE at 0 demand.
At the end of braking for turn 1 the ICE runs in a cut cylinder mode to help us hear that it is motoring, thanks Honda. The only place the power can go, under the rules, is to the MGU-K.
Apart from harvesting some extra energy, I’m guessing this helps with driveability and throttle pick up. At the point of throttle pick up the ICE is potentially already producing about 20% of its max, the turbine is providing some power to the compressor, reducing ES drain to the H. As the demand increases the delivery can mix K and ICE to provide a smooth match to the demand curve with no lag, and the turbine can take over full responsibility for driving the compressor early.
This behaviour works well at Monza, and most tracks, where the 2MJ K>ES limit is not satisfied by harvesting under braking over the lap. It would be interesting to find a video of the Singapore to see if the behaviour changes.
