I have also been corresponding with Ringo on the nature of Torque. This is my latest reply to him:
ringo wrote:Torque is not a force. That is for certain.
Force is not potential energy i agree, but a torque is not a force as i said. You made that claim.
I made no such claim. What I said is that Torque is the
rotational equivalent to Force. Not equal to Force, but analogous.
ringo wrote:It is a tendency of a force. It is not a force. It cannot be equivalanet to a force if it is a product of a force and something else.
As above, I never said Torque was a Force or equal to Force. You misinterpret or misrepresent what I mean by
rotational equivalent. By that I mean that Torque works in rotational systems the same way force works in linear systems. I will hopefully prove that to you below.
ringo wrote:It makes sense, becuase pi is a dimensionless number. it is a quantity. No units, so it doesn't affect the physical nature of what a torque is.
And it goes to show you that For a torque to exist energy must be expended. If you want a torque to exist for 10 revolutions you will obviously see that energy required will be 20π Joules.
No, it doesn't make sense. Dimensionally 2π Nm = J, but physically and mathematically it does not.
The 20πJ after 10 revolutions is the amount of work done by 1Nm over 10 revolutions (20π radians).
Torque can, like Force, exist without doing work. Example, I can push as hard as I like against a big brick wall, but I can't move it. I may have expended energy, but I haven't doen any work.
Similarly Torque can exist without rotation. If I bolt my torque device to a similarly solid structure, I can expend energy applying torque without doing work.
ringo wrote:It is not a confusion. It is a similarity. I have stated the difference already. Once has a direction, a vector quantity, the other doesn't, a scalar quantity.
It's like the difference between velocity and speed. Both are the same fundamentally and different functionally. One had direction the other doesn't. But at the end of the the day they can be manipulated in the same manner. Like your example below with the drum.
Yes, you are confused.
Energy/work and torque are very different concepts, whose units just happen to match dimesnionally.
ringo wrote:Energy transfer right there. You are shooting your own argument in the foot.
What? That 1J work in a rotational system can be translated to 1J work in a linear system. Shocking!
But I can use 2,000,000Nm to get the same 1J of work. It is all abou the displacement.
ringo wrote:Power = Energy/time, Power= torque x angular velocity (radians per second)
Power is not force x time. You calling a torque the equivalent of a force is categorically wrong.
You cannot dispute this.
You are being deliberately diingenuous.
Angular velocity is not time.
Power = torque x angular velocity
is equivalent to
Power = force x velocity
Let's break this down further.
Rotational work is W = T x w (where w = angular displacement).
Linear work is W = F x s (where s = linear displacement).
Power = work/time, so:
Power = (T x w)/t = T x w/t = T x angular velocity
Power = (F x s)/t = F x s/t = F x V
The factor that changes between linear and angular systems is radius (r).
T = F x r
w = s/r
Angular velocity = V/r
Angular acceleration = a/r (where a is linear acceleration)
Torque is the rotation equivalent of force in the same way that angle is the rotational equivalent for position, angular velocity for velocity, and angular momentum for momentum. As a consequence of Newton's First Law of Motion, there exists rotational inertia that ensures that all bodies maintain their angular momentum unless acted upon by an unbalanced torque. Likewise, Newton's Second Law of Motion can be used to derive an analogous equation for the instantaneous angular acceleration of the rigid body
http://en.wikipedia.org/wiki/Force#Rotations_and_torque
ringo wrote: It's the conservation of energy that describes the relationship between torque increase with speed reduction.
If you have two gears in contact, both must have the same tangential velocity at the contact point.
torque x angular velocity of gear1 = torque x angular velocity of gear2
If one torque is doubled, the other will be halved. It is this vector quantity that you all are ignoring.
Tangential velocity of the two gears will be the same at the point of action. However, their angular velocity will not be.
If R1 does not equal R2 then:
w1 = V (tangential velocity)/R1
w2 = V/R2
and w1 cannot be equal to w2.
That last staement doesn't make sense. The driving gear's torque will remain whatever it is, while the driven gear's torque will be doubled (for a 2:1 reduction). The angular displacement of the driven gear will be half that of the driving gear, 1Nm x 1rad/s (driving gear) = 2Nm x 0.5rad/s (driven gear), and thus energy is conserved.
Torque is not conserved. Power is (as it is energy over time) - power on the input is the same as power on the output (ignoring losses). As you pointed out, power is work/energy/time.
ringo wrote:In conclusion, i am not calling torque scalar energy like heat or whatever other forms you have. All i am saying is that it is more related to energy than a force. In fact it can be converted directly to energy as you have demonstrated with the drum. Only energy can turn to energy.
Work is performed by Torque and angular displacement. And work is performed by Force and linear displacement.
Neither Torque or Force can do work without displacement.
ringo wrote:A force is a constituent of torque. They are not equal.
I never said they were. I said, and the all-knowing Wiki backs me up, that Torque is the
rotational equivalent of Force.
ringo wrote:Any torque that exists can be turned to energy. And this is why you have your KERS working on your drive axle in the first place when you brake. Or a wind turbine, The same can't be said of a simple force in isolation.
If you apply a torque without rotation (which you can do) then you aren't converting it into energy. It needs displacement to do work.
