DaveKillens wrote:I still believe the carbon fiber arms carry the entire load, with metal slip-on shrouds in the high heat area. In the first posts, ginsu displayed two pictures, the first showing the lower arm with the metal shroud, and the second showing no shrouds, just pure carbon fiber arms. I believe that is still what they use, carbon fiber arms for mechanical loads, protected by metal shrouds.
In my eye, the metal shrouds appear to be slip-on, and do not appear to have a tight "bond" with the carbon fiber arm.
yea Mikey_s, those are great pics and do show a very low mounting point for the rear calipers. Why not lay them flat instead of giving a slight inclination? My theory is to make bleeding the brake system practical and easy. Having calipers flat would make bleeding all the air from the brake system a nightmare.
Great pics on this thread! It is for heat and heat shields almost by definition do not come in contact with the object they are shielding. That is why it appears so large/wide/thick.
The calipers are mounted that way because of the hub design on the inside of the wheel. Because of the suspension pick up points (mounts), it cannot be at 6 o'clock. In the front it is hard to get the calipers much below the 4 o'clock position because of the steering.
They can mount the bleed hole anywhere in the caliper. Depending on it orientation when mounted, they simply tap into the highest point.
Innovation over refinement is the prefered path to performance. -- Get rid of the dopey regs in F1
