Page 2 of 3
Re: Rep/notifications technical issue
Posted: 26 Feb 2021, 11:05
by zibby43
Steven wrote: ↑23 Feb 2021, 15:01
As for mentioning people with @ , the developers of phpbb (software package we use as a basis here) have moved this ahead to a future release. It was initially meant to be available already.
I'm a contributor to that project, so I try to steer things a bit according to our wishes, but I don't have the time to implement it all myself
And with regards to the notifications issue... I'll update here when a fix is coming/deployed. Just a tiny little bit more patience please
Posted: 01 Sep 2021, 10:32
by GOAT
Just found out that there is this ‘reputation’ system on this forum.
I have a ‘question’ for Steven and his ‘Gladiators’;
While viewing my profile, I noticed my ‘reputation’ of -2.
app.php/reputation/details/0/0/0/0/43513
Then when I look at:
“ Ratings for user GOAT”
It states that:
“ Reputation changes for deleted posts or topics are not shown here.”
.. this is not correct, as reputation changes for deleted posts are still shown ánd still count.
Furthermore, it’s clear people are misusing the downvote system- but I don’t mind.
Whatever makes ‘you’ happy, I am just thankful I could be a part of it.
Posted: 01 Sep 2021, 11:07
by Wouter
zibby43 wrote: ↑06 Feb 2021, 21:08
Wouter wrote: ↑06 Feb 2021, 21:00
zibby43 wrote: ↑06 Feb 2021, 20:28
Ever since the site update, I don’t receive notifications for rep or post replies.
I also can’t upvote other posts. I have to reload the page, or the vote is stuck in “submitting” status in perpetuity.
Noticing this on both mobile (Safari on iPhone with most recent iOS) and laptop (Firefox).
Anyone else? Any recommendations? Thanks in advance.
Ever since the site update, I don’t receive notifications for upvotes. Noticing this on laptop (Firefox).
Thank you for confirming I wasn’t the only one. Looks like we have the browser in common on the laptop.
As an update, notifications for posts now seem to be working on the phone with Safari and iOS.
I still don't get notifications about votes.
We waited just
a little bit longer now, from February to September.
Is there any news yet?
Posted: 02 Sep 2021, 13:37
by RZS10
I wasn't even aware that there's supposed to be notifications for recommendations/ratings and i honestly can't recall ever getting one
GOAT wrote: ↑01 Sep 2021, 10:32
It states that:
You misunderstood this - any positive ratings will be removed (or at least should be, mods sometimes forget) when the post gets deleted as posts which are worthy of deletion should not yield positive reputation.
However any negative reputation will stay even if the posts get deleted, otherwise this would turn the forum into a troll's paradise if the well earned negative rep would disappear with all the off topic posts/trolling.
On a sidenote: The misusage of the voting system is far more prevalent for positive ratings.
Posted: 02 Sep 2021, 15:41
by GOAT
RZS10 wrote: ↑02 Sep 2021, 13:37
It states that:
You misunderstood this..
I do believe I did not, thank you very much;
reputation changes covers positive- and negative changes, there is no exception.
Therefor downvotes for deleted posts should not be visible.
Posted: 02 Sep 2021, 15:46
by RZS10
You were seemingly unaware of the system in general so i thought i'd give you an insight into how it works - obviously if you disagree with the wording of that sentence or want to be extremely nitpicky about it you can shoot the mods a message and maybe they will be so kind as to remove the visibility of your negative ratings from that overview (obviously leaving the ratings themselves) - but it's unlikely since they're there for a reason, which is learning from past mistakes. You can also suggest a change of the wording which more than likely will and should be ignored because it's something not a single person had an issue with so far.
Posted: 02 Sep 2021, 19:28
by GOAT
RZS10 wrote: ↑02 Sep 2021, 15:46
Your answer says it all; I do not need to know a ‘system’ in order to spot an error.
I am pointing out the discrepancy- when it’s wrong, it’s wrong and it should be revised + corrected.
Instead I get ignored by the people operating this website.
The same people who are immediately there to hand out warnings for ‘trolling attacks’ and such nonsense..
The most comical part is that you mention it should simply be ignored, because nobody ever noticed it.. if only I were that ‘simple’, my life would be a lot ‘easier’.
-edit-
If I receive a warning for the type of words I choose, then those same people should make sure that their own wording is impeccable.
Posted: 02 Sep 2021, 19:51
by GOAT
Btw.
Just noticed your chosen wording in this post.
“Well earned”
In my case, someone used up all their downvotes for that day on me- I received several downvotes in consecutive minutes, with similar comical explanations; clearly someone was trying to make a point…
Posted: 02 Sep 2021, 20:07
by nzjrs
GOAT wrote: ↑02 Sep 2021, 19:51
Btw.
“Well earned”
People with rep can only downvote each poster once, and only IIRC something like 2 downvotes per day. It appears that people independely determined your posts worthy of spending their limited downvotes on.
Posted: 02 Sep 2021, 20:13
by GOAT
nzjrs wrote: ↑02 Sep 2021, 20:07
I did not say all downvotes went to a single post; but it is to be expected some are ‘ganging up’.
The best explanation for a downvote was:
wtf are these upvotes”
Posted: 02 Sep 2021, 22:05
by RZS10
Btw.
“Well earned”
I hadn't checked your ratings when i posted that, it was just a broad phrasing in the explanation as i do believe that the negative ratings on average are usually fair, i have that much faith in a vast majority of longtime users here, same as i believe that mods would not delete a post without reason.
I'm not sure whether this is the right place to disect your ratings but the only incorrect negative one i see is "wtf are these upvotes" but not because it's wrong (it isn't, see below*) but because users aren't supposed to offset ratings they disagree with, i can't see one of the posts but as mentioned already i'm sure the mods had every reason to delete it.
In general the reasoning for the ratings is supposed to give the users a chance to see why they received it, to allow for some introspection - or as turbo1 wrote in a PM and surely doesn't mind me quoting him:
The rating system is not meant as a like/dislike button [*see above]. Offsetting objectively correct negative ratings with positive rating[s] is obviously not allowed. Feedback [of motivation for negative ratings] has to be constructive and has to help the member avoid objectively wrongful posts in the future.
I don't know if dismissing all those ratings as comical or "ganging up" (which nzjrs pointed out surely isn't the case) is the correct attitude, but that's just my personal opinion.
You can always write a PM to the mods if you sincerely believe that any ratings you received were unfair, just as you could start a seperate thread politely asking if they could potentially add the word "Positive [...] " to the sentence on the overview page to better reflect what it shows if you truly believe that it is necessary - it will bring you further than hijacking a thread about missing notifications for your complaints.
Posted: 02 Sep 2021, 22:27
by jjn9128
GOAT wrote: ↑02 Sep 2021, 20:13
You'll notice when you click the upvote button it says "Rate up to recommend this post as valuable and of technical value". The emphasis on technical value as this is a technical forum - or at least the threads I frequent are. From my understanding mods have the power to remove upvotes where it's just cohorts of people agreeing with one another - that's not the point of the upvote. Similarly the downvote tool can be used to single out content which has little or no technical value - you know, on a technical forum!
So "wtf are these upvotes" would seem to indicate someone is flagging tribalistic upvoting of a technically bereft post so the mods can check. Which given the post was,
True.
A
L
O
N
S
O
Would be great to see.
which I would frankly agree with as it offers nothing of technical value so what exactly are you complaining about?
Posted: 03 Sep 2021, 05:31
by zibby43
I’ve gotten used to how the system operates now. Guess we’re just going to have to live with it?
At least I’m getting notifications for quoted posts again!
Posted: 03 Sep 2021, 11:01
by GOAT
jjn9128 wrote: ↑02 Sep 2021, 22:27
True.
A
L
O
N
S
O
“ Feedback [of motivation for negative ratings] has to be constructive and has to help the member avoid objectively wrongful posts in the future.”
How does “WTF are these upvotes” relate to “Feedback for negative ratings has to be constructive..”
My complain? Negative/positive rating changes for deleted posts should be made not visible, as stated.
Current policy does not comply with what is written- obviously they can change what they have written, but that doesn’t apply retroactively.
Posted: 03 Sep 2021, 12:25
by RZS10
What exactly do you want changed? Do you want negative ratings of deleted posts removed? Or do you want the text changed? Seems like you're just stirring the pot for the sake of it.
