raymondu999 wrote:yeah. Gs would just denote the acceleration. When you corner faster it would invariably give you a higher g in lateral loading
NASCAR. Indianapolis. 2008.Giblet wrote:Possibly silly question, but could tires be made to not marble?
Not sure I can agree with the above statement or, perhaps, I have mis-interpreted it. To be clear, there is a direct correlation between spring/tyre stiffness ratio & heat absorbed by the tyres as measured on a four post rig (with fixed cambers, mean vertical loads, bars & dampers). The characteristic appears to translate well to the track/road.marcush. wrote:....if you have a bit too much compliance in your suspension this will also raise tyre temps....
i should have been more precise..Iwas not talking about springs and dampers ,i was talking about the compliance of suspension members ,be it slack in joints or parts deforming and thus altering intentionally or unintentionally geometries ..and so altering slipangles ,caster ,camber and what have you dynamically.this contributes very much to tyre temps.DaveW wrote:Not sure I can agree with the above statement or, perhaps, I have mis-interpreted it. To be clear, there is a direct correlation between spring/tyre stiffness ratio & heat absorbed by the tyres as measured on a four post rig (with fixed cambers, mean vertical loads, bars & dampers). The characteristic appears to translate well to the track/road.marcush. wrote:....if you have a bit too much compliance in your suspension this will also raise tyre temps....
Hey. Not sure I quite understand what you mean.Jersey Tom wrote:NASCAR. Indianapolis. 2008.Giblet wrote:Possibly silly question, but could tires be made to not marble?
raymondu999 wrote:Hey. Not sure I quite understand what you mean.Jersey Tom wrote:NASCAR. Indianapolis. 2008.Giblet wrote:Possibly silly question, but could tires be made to not marble?
Ha.. Thank you, Marcus. All is explained (& I agree). Suspension compliance will allow hub movement without troubling the dampers & the resulting uncontrolled hub modes certainly can work the tyres.marcush. wrote:i should have been more precise..Iwas not talking about springs and dampers ,i was talking about the compliance of suspension members ,be it slack in joints or parts deforming and thus altering intentionally or unintentionally geometries ..and so altering slipangles ,caster ,camber and what have you dynamically.this contributes very much to tyre temps.
I have worked for Ohlins a few years back and they had some fancy slag in their damper piston mount (they called High frequency piston) to raise the tyre temps..on those ultra smooth tracks...DaveW wrote:Ha.. Thank you, Marcus. All is explained (& I agree). Suspension compliance will allow hub movement without troubling the dampers & the resulting uncontrolled hub modes certainly can work the tyres.marcush. wrote:i should have been more precise..Iwas not talking about springs and dampers ,i was talking about the compliance of suspension members ,be it slack in joints or parts deforming and thus altering intentionally or unintentionally geometries ..and so altering slipangles ,caster ,camber and what have you dynamically.this contributes very much to tyre temps.
