What are you talking about exactly ? what did they close ? and what is amateurish ?McG wrote:Was thinking that myself. They say the lotus works better with with hotter tyre temperatures and Spa was a bit cold. Seems a bit amateur to try something like this. Surely they should have known they would be overcooking their brakes , even without this botch job, because of their grid position, being behind cars for a lot of the race. Reminds me of the type of rough upgrade that McLaren did with cutting chunks out of their rear floor.Ral wrote:That seems plausible.
Do you guys think it's possible that's what's caused Raikkonen's brake failure today? He has been struggling to get front tyres up to temp and if they've closed the brake drums to help him with that, it might have been a bit too much?
Lotus are running out of ideas if this is the type of approach they are taking. But I guess Allison took all the new ideas with him. Lotus might struggle for the rest of the season, and in turn Raikkonen will leave.
The new brake/wheel fairing is a big and a smart update IMO. Enstone cars have been running the same design for many years. So the new design is a big evolution. It adopts the 'scope-less' configuration of the Williams design, it keeps the strong points of the old design (part of the disc is naked so it can transmit some of the heat to the wheel rims) and they adopt some of the strong points of the modern brake covers (like the way they channel hot air outside the wheel in order to improve airflow).
