xpensive wrote:I don't think you use the windtunnel as means of load-testing.
DF is a load, right? However, I have not a clue about materials or whether an F1 team uses the same manufacturing process for their wind tunnel models as their final cars?
In all seriousness, it's the QA (quality assurance) process which has failed here, which is probably caused from being a new team and not having those measures properly in place yet. Whether that raises safety concerns the FIA and FOTA should decide.
This still could be a failure of CFD, though, as I assume the parts manufacturers where given some tolerance for the loads on the wing and it may have exceeded those loads in real life. Experimental work would have confirmed those load predictions. However, we don't know if it was this failure in the QA process that caused the problem or not - it may have simply been an undetected manufacturing fault.
