Now, let's take a
closer look:
The tips of the 2 halfs of the wing are already scratching the tarmac, so
some kind of failure has already happened here. Both halfs are
drooping down straight, not bent, and both pillars are bent
inwards so it was a longitudinal crack on the wing itself somewhere between the pillars.
Looking close, I can swear I see the break close to the right pillar of the wing.
This is the tricky part. The aero loads on the wing are
higher between the pillars and the ouside of the wing, so the wing was being able to deal with those. What this leads us to? Being a guy with some experience on the behaviour of metals rather than carbon fibre, it does look to me like a
fatigue induced failure: it happens on the only zone
(between the pillars) where the wing is submitted to
alternate loads passing the neutral point (its
unstressed shape) and close to the pillar. The problem is, the little information I'm able to find about fatigue behaviour of carbon fibre say that it's lifecycle is virtually infinite. Some studies I found
on the netzz concerned this issue but were available for subscribers only. I figure there are many members on this forum than could
enlighten me on if carbon fibre experiences any fatigue...
Another pic:
Since the wing is a fairly rigid body (well, when we see those
super slow motions...) surely the center of the wing should experience considerable stress just cancelling the aero load moments.
But if that stress would be the guilty one, the rupture should happen right in middle of the wing
(and, you know, I can swear I can see it closer to the right pillar...).
Naturally, it could also be a fabrication problem but, if that was known to be the case, there would be no sense on stopping the car for the remainder of the day, since I can't simply believe the team had a single nosecone. Same case with Wirth's
mounting problem excuse, besides I can't possibly imagine how the mounting of the nose in the chassis could induce the failure we saw.
Concerning the total failure after the turn,
that easy to explain (ufff...). The pillars were bent because the rigid and simmetrical nature of the wing usually cancels the moments around the
z axis. By braking around the middle, the wing ceased to do so and pillars are not designed to withstand this kind of bending. So, they finally broke, seemingly on the pillar/wing interface.
