Hello Pinger.
You write:
“If the above is such an advantage, Mercury, Evinrude, et all must rue shifting from cross-flow scavenging to loop, as with cross-flow scavenging they enjoyed an exhaust port width that easily matches yours.”
They could shift to cross-flow to achieve a faster blow-down.
But the side effects of the cross-flow scavenging make it a worse solution.
On the other hand, with the classic loop scavenging the exhaust port can be larger and larger (in expense of transfer port area and of short-circuiting) to give a faster blow-down at higher revs.
Quote from page 133,
https://www.f1technical.net/forum/viewt ... start=1982 :
Here is the port map of the famous Aprilia RS250 of 1999 (two cylinders in V90, oversquare design with 56mm bore and 50.6mm stroke):
The porting is focused on the faster blowdown: the “peak” (?) exhaust duration is 209.3 degrees and the “typical” (?) exhaust duration is 193.4 degrees, while the duration for the side transfer ports is only 129.6 degrees and the duration for the boost port is only 127.3 degrees.
The transfer is not only 64 degrees narrower than the exhaust, but its maximum (at the BDC) is not bigger than the maximum of the exhaust.
The above way of presenting the porting of a 2-stroke does not fit with the asymmetrical porting of the PatATE.
Here is a different presentation of the porting of a, say, modified to PatATE Aprilia RS 250:
The ports of the Aprilia RS250 are shown by black line.
The red triangular is the exhaust of the PatATE RS250, the blue triangular is the transfer of the PatATE RS250.
Going from top to bottom:
The exhaust of the PatATE starts opening substantially later (at, say, 87 degrees before the BDC) than the exhaust of the original RS250 (which opens at 105 / 97 degrees before the BDC).
The (red) exhaust opens at a higher rate than in the RS250.
Soon the exhaust area of the PatATE gets larger than the exhaust area of the RS250 (and as mentioned before, the Aprilia RS250 is focused on a larger exhaust area for the sake of a faster blowdown).
Some 20 degrees later the transfer (blue) of the PatATE starts opening at a very slow rate, giving time to the blowdown to complete. At the angle wherein all the transfer ports of the original RS250 open, the area of the transfer of the PatATE is still quite small, with a substantially smaller rate of increase.
At the BDC the rate of exhaust closing and the rate of transfer opening of the “PatATE” are about the same.
At the BDC the area of the exhaust port is still larger than the area of the original RS250 exhaust port.
As the piston moves towards the next (lower in the diagram, see the beige arrows) TDC, the transfer of the PatATE strengthens and the exhaust weakens / reduces until it closes completely.
For another 20, or so, degrees the transfer of the PatATE remains open to complete the transfer, while the exhaust is closed.
According the plot, the transfer remains open several degrees later than the transfer of the original RS250; also the exhaust of the RS250 remains open several degrees after the closing of the transfer of the PatATE.
On the same diagram, going from left to right is like moving along the periphery of the cylinder, with the zero angle being at the center / middle of the exhaust ports.
The exhaust of the RS250 covers, at maximum, about 120 degrees on the periphery of the cylinder, the transfer of the RS250 covers the rest cylinder but has, necessarily, substantially shorter height.
The exhaust and the transfer of the PatATE extend, each, for some 180 degrees along the periphery of the cylinder, but they are substantially asymmetrical relative to the BDC: the exhaust is significant before the BDC (blowdown, upped half of the plot) while the transfer is significant after the BDC (filling of the cylinder by the compressed gas in the crankcase, lower half of the plot).
The height of the transfer and the height of the exhaust are equal.
End of Quote
You also write:
“Well if that is so effective why do all the 2Ts that operate at higher than 4bar BMEP employ a returned -ve pulse to achieve that effect?
Didn't read up on exactly where the pumping losses in a 2T occur - did you?”
In the following post - reply to Uniflow - the BMEP of the OS18TZ is well above 10bar.
And, unless I am wrong, it is not based on a tuned exhaust.
Thanks
Manolis Pattakos
