saviour stivala wrote: ↑29 Dec 2018, 19:49
PlatinumZealot wrote: ↑27 Dec 2018, 16:43
Nice..
The exhaust ports are quite small.
Wastegates are relieving the turbine housing. Not really ideal for keeping flows steady near to the wheel.
A big cooling trunk is needed for the turbine cartridge or is that one of the compressor outlets? (yeah crazy if this thing has two)
Wastegates does not relieve the turbine, they bypass it.
I'll take the bait.
When PZ said "relieve the turbine housing," he means that that the wastegates are relieving the exhaust gas pressure at the turbine housing (which bypasses the turbine wheel) instead of at some other point on the exhaust tract.
There is a misunderstanding on your part as to what he means. What you said (bypassing the turning) doesn't contradict what he said, he was simply stating where the wastegates are located.
By the way you type it appears that English isn't your first language so it's understandable however from what I've seen, this isn't the first time you have tried to contradict something someone said when actually you are in agreement with them. This causes conflict where there is none.
