Ferrari SF15-T Pre-Launch Speculation Thread
Facts Only
Facts Only
188
Re: Ferrari 666 Pre-Launch Speculation Thread
Alexgtt wrote:
Sevach wrote:Split turbo doesn't mean "just like Mercedes did", if there is separation between the turbine and the compressor it's split.
Absolutely correct. The shaft connecting exhaust turbine from compressor turbine has to be ONE SHAFT according to the rules. There are no couplings/joints. Therefore the definition of split turbo in this case means turbos without compressor and exhaust bodies mounted on a common core.
Nope, you can have as many shaft parts as you like as long as they rotate about the same axis at the same speed.
Don't worry though I've only designed a couple of these turbos now so I'm sure I know hat I'm talking about.
lio007
316
So,Ferraris split-turbo-layout could look like this:
467
aleks_ader wrote:Also they could move MGU-H inside clutch bell with drop gear assembly... Like they did with ERS-K or MGU-K. Then you move oil tank in common position infront engine and redesign clutc&bell case to accommodate structure to the free space and its relocated "bigger" turbo assembly. Also that you coul literally feed ERS-H direct into ERS-K (+ CE off-course). A lot of IF...
I'm not sure that would be such a good move, because you're adding a side load into the turbo's shaft. The in-line solution would be better, with an epicyclic gearbox for speed reduction.
Alexgtt
Alexgtt
Very good and noted however my comment wasn't a slight on anyone's reputation so why get so defensive? My main point remains............Ferrari had a split turbo.
aleks_ader
90
Excellent!
Off-course that would be the main problem, but who said it would be easy. :D Between friends we also discussed about ceramics ball bearings of the turbo shaft (they could easily handle 200 kRPM).
So the additional loading could be "redefined" with recalculation of size of bearings, adding clever damping&clutch elements and the redesign shaft diameter (to maintain the "centering" and avoid critical rotational RPM of the shaft).
But at the same time you make pros:
1. coke bottle is much more tighter and narrower (no compromise to make longer wheelbase or smaller turbine dia=30mm room to resize),
2. lowers the CofG, less stress on top of the cover (less weight to support complete exhaust and waste-gate assembly),
3. improve cooling of the ERSA and MGU assembly. Colling became more effective and easier to control (also you could reduce cooling of MGU-H unit or do reverse trade-off and for same car "heat footprint" reduce the weight of MGU)
4. possibility of the direct E-link toward ERS-K
5. Overall packaging of the back of the engine and clutch-bell became much more evenly distributed.
6. Exhaust could became much shorter, hence lees weight (200 mm for sure)
cons:
a. without clutched assembly the TURBO unit response could be seriously compromised due additional rotational inertia, lag could be even worse; adding the clutch make the assembly a heck more difficult + heavier
b. added additional side load due gear meshing =reduced life of the TURBO unit, redesign needed described above
c. additional weight due additional bearings, gearings and housing (but maybe that could even out with point no. 2)
d. add mesh losses, accordingly drop gear meshing max 5%
d. the oil tank need to be relocated, so 1 token for "oil ancillaries" is wasted
467
The oil tank can be relocated without needing the MGUH geared off the turbo's shaft.
The MGUH -> MGUK cannot be a direct electricallink - it has to go through the controller to match the required frequencies, voltage and current. This also enables the MGUK to be fed from both the MGUH and ES at the same time.
I'd suggest the best option would be to have the turbo and MGUH in the same way as the Renault. I assume that they cannot do the Merc style for some reason.
Xwang
Xwang
29
The turbo compressor axis should be parallel to engine shaft or can be in any direction?
467
Xwang wrote:The turbo compressor axis should be parallel to engine shaft or can be in any direction?
The turbine, compressor and connecting shaft all have to be co-axial and parallel to the crankshaft axis.
Bomber_Pilot
Hail22
144
Don't know if this has already been posted but i found this while trawling the net today:
Interesting suspension geometry...could it be the 2015 Ferrari or just a fan made render?
Gilles Villeneuve
FW17
169
Expecting the new Ferrari to be good.
The F14T with a bad engine was almost a match for the Red Bull car and this was with a nose which would be legal in 2015. If the engine is improved dramatically, it would be a good season for Ferrari.
Looking forward to them beating Red Bull for the first time since 2010
Moose
Moose
52
Hail22 wrote:Interesting suspension geometry...could it be the 2015 Ferrari or just a fan made render?
Looks very like Merc's 2014 geometry. I wouldn't be surprised if the answer was "both" - that is, that Ferrari have copied Merc's suspension geometry, and a fan has copied Merc's suspension geometry.
That's a W05 painted Red.
Pedrolito
Thunders wrote:That's a W05 painted Red.
Yes, it's so close...
http://www.omnicorse.it/magazine/43190/ ... a-diapason
bonjon1979
bonjon1979
30
It's not close. It is that same image of the Merc just painted red.
