[MVRC] Mantium Virtual Racecar Challenge 2018
Team_Bart
Re: [MVRC] Mantium Virtual Racecar Challenge 2018
CAEdevice wrote:
22 Aug 2018, 16:23
Simply the fender has to be inlcuded into the "carbody" volume, that you can find in the template.
https://ibb.co/i3oyDU
Ah I understand now, there was probably a visualizationproblem when opening the control assembly. When opening the full assembly, the bodywork volume has no right side (see figure). When I open only vol_bodywork.STL file it has, so I can use that one :)
CAEdevice
49
Team_Bart wrote:
25 Aug 2018, 11:42
CAEdevice wrote:
22 Aug 2018, 16:23
I confirm, the official template sometimes gives this iusse (since 2017): it depends on the CAD you use to import it (ex. with Creo that surface is ok, with Solidworks not).
I am not sure to remember correctly, but I put a link on this forum with a "mirrored" and corrected version of the official template in STEP format..
LVDH
46
Interesting. I checked yesterday and everything look OK. I will look further into it this Monday.
Tomorrow at 1.00p.m. you guys will be able to see the results of the race.
machin
162
Under two hours to go... We've got all the cars ready to go out and set some quick times...
LVDH
46
So guys, here you go:
variante
138
Cool! Congratulations to CAEdevice, JJR and Pure Power R. !!
I kinda expected CAEdevice to win, considering last year results... But I also expected JJR to pull out some more downforce, as he usually does.
As for me, I had a very stupid cooling problem. It has already been solved without performance losses, so I expect a very good result for the next race.
Congratulations to the other guys too, and I'm sure the new ones will progress very quickly.
etsmc
etsmc
Was hoping for better but knew it was going to be a poor result. Congrats to pure power racing. We were battling last year but i think you are going to walk away from my car this year. Good work to the new comers also not too far off the pace considering.
Ft5fTL
26
Congratulations to all the participants and congratulations to CAEdevice for the victory. Feels rather nice to get to the podium for a change. However i dont think i can replicate that again on the upcoming races.
Mantium Challenge - Pure Power Racing
CAEdevice
49
I see the results only now (I was climbing in a place were there is not any internet connection).
The new video with the race is fantastic! Very good job. After 60% of the the lap I was a bit worried.
JJR best opponent as always, congratulations! Pure Power confirms its improvements.
Not a good result for Variante but with very interesting numbers: he will fight for the first place in the next races.
The intro car, despite some design errors caused by inexperience of the new team (Vortex), looks very competitive.
For the next race I will introduce two new concepts (it is too early to show them now, but I will do before race 2). They will not improve immediately the performance but they are promising for the 3rd race.
machin
162
Yes, this format was the only way I could think to get you a little worried! 😀
From our point of view the "best" track layout would be one with one big long corner (so the cars with lots of downforce would pull out a lead), followed by a big long straight (so the cars with low drag would claw back and hopefully overtake!).
Congratulations to all involved. 👍
variante
138
machin wrote:
26 Aug 2018, 22:10
After the first set of corners I almost thought the impossible could become reality... :cry:
etsmc
etsmc
just downloaded my official results and surprised to see some of the images were a bunch of music playlists and also some Linux cli.. anyone else get this?
But i did find out that i thought i was going to be down on power due to cooling but was not the case.. :)
machin
162
variante wrote:
26 Aug 2018, 23:36
machin wrote:
26 Aug 2018, 22:10
Well, joint third isn't too bad! 😊
I suspect that CAEdevice was probably ahead even by that first point; the video shows two speed trap readings rather than sector times; basically because we have no driver variables most of the time the cars have sorted themselves out into winning order after a couple of corners... That's why I avoided sector times...
LVDH
46
etsmc wrote:
27 Aug 2018, 09:02
I just deleted all reports. I will recreate them Tuesday and send new ones out. This sometimes happens when I get bored when the reports get generated and I start surfing.
etsmc
etsmc
LVDH wrote:
27 Aug 2018, 09:36
etsmc wrote:
27 Aug 2018, 09:02
Thats all good dont worry about resending it. The info is irelevent as the car has developed alot since this race.
