via AutoSport
A counter argument is that Mercs front end is so good, because of its unconventional FRIC suspension which ensures that it both doesn't dive under braking and remains aerodynamically stable under cornering.theformula wrote:About this whole mercedes overheat their rear tyres thing - Could it be that they are not producing enough downforce at the rear of the car relative to the front? As it has been said by numerous "techy" people (eg. gary anderson, mark hughes) that merc have a strong front end and because of this strong front end the rear of the car is unable to keep up and therefore the rear wheels slide and more heat builds up. I think they counteracted this slightly by having less front end in hungary but whether doing this for the rest of the races in 2013 is favourable is questionable as they may not always get the balance right. So could part of the solution to their tyre woes be producing more rear downforce?
Perhaps its because mercedes is having problem warming the rear tires. The black strip is a way to crate a next to ideal black body to absorb the heat generated by the rear brakes. The amount of heat the wheel can take in is simply a function of the width of the strip.SectorOne wrote:If it´s just a sticker, what purpose would that fill?
I´ve zoomed in on the big picture and it looks like a cavity to me.
The way I understood the problem was that because of the good front end down-force the Mercedes can turn quicker, meaning that they can accelerate earlier out of corners which means that the side load on the rear tires increases. That combined with the stiff construction of the 2013 tires led to the overheating issues.theformula wrote:About this whole mercedes overheat their rear tyres thing - Could it be that they are not producing enough downforce at the rear of the car relative to the front? As it has been said by numerous "techy" people (eg. gary anderson, mark hughes) that merc have a strong front end and because of this strong front end the rear of the car is unable to keep up and therefore the rear wheels slide and more heat builds up. I think they counteracted this slightly by having less front end in hungary but whether doing this for the rest of the races in 2013 is favourable is questionable as they may not always get the balance right. So could part of the solution to their tyre woes be producing more rear downforce?
I agree with this, here's a very nice video of the pit stop practice of the team at Canada. Plenty of chances for seeing the rims. Particularly, 2:07, the thing is a groove, with something plastic inside:Blaze1 wrote:I've just re-watched the British Grand Prix. Nico pits at the end of lap 42 and during this time there is footage of a mechanic holding a new left rear wheel. As the mechanic holds wheel small movements of it allow sunlight to glint off its inside edge and for a brief moment the light touches the black strip. It becomes quite clear the strip isn't a cavity.
smlbstcbr wrote:I agree with this, here's a very nice video of the pit stop practice of the team at Canada. Plenty of chances for seeing the rims. Particularly, 2:07, the thing is a groove, with something plastic inside:Blaze1 wrote:I've just re-watched the British Grand Prix. Nico pits at the end of lap 42 and during this time there is footage of a mechanic holding a new left rear wheel. As the mechanic holds wheel small movements of it allow sunlight to glint off its inside edge and for a brief moment the light touches the black strip. It becomes quite clear the strip isn't a cavity.
http://www.youtube.com/watch?v=FzOdmKYp ... MA&index=1
Nice Picture off the rim ,tony77g wrote:Matt Somers wrote:My conclusion is it's a strip of tape or paint too... That image although enlarged doesn't show the full extent of the imperfections near the edge if it were an aperture...
My 2p's on the subject...
http://somersf1.blogspot.co.uk/2013/07/ ... trick.html
Totally agree with you Matt, and add this photo. It might help you figure out who still insists
watch the yellow line
http://www.zaslike.com/
