I thought maybe I should quote myself from the regulations thread. The newest issue of Racecar Engineering has an article from an ex-f1 aero guy explaining why "ground effect" wouldn't fix things.
[/quote="Pierce89"]Every real study into the problem, has shown that "GE" based solutions are not any more benign or robust in aerodynamically than "wing" based solutions. Unfortunately the only way to fix the problem is greatly reduce reliance on downforce. Anyone who thinks conversion over to shaped venturi tunnel floors will fix the current problem hasn't really done any real reading of all the available studies.
Remember the OWG that designed the 2009 regs actually tried their best to neuter the diffuser, because their WT studies showed that GE was no magic bullet to fix the overtaking/traffic/turbulence problem f1 has.[/quote]
