Renault R28 aero-mech development in 2008
Steven
Owner
Re: Renault R28 aero-mech development in 2008
bar555 wrote:
Neophiliac wrote:Given the selective closing of the right chimney on occasion, is it a safe bet that the ECU is somewhere on the left side, necessitating extra cooling on occasion?
This something that only Scarbs could tell
The oil cooler is on the left, requiring an extra bit of cooling.
modbaraban wrote:I thought (for some reason) that the ECUs, data loggers etc are located somewhere behind the front suspension. :?
Data logging systems are usually closely packaged around the engine or gearbox to reduce cables.
bar555
bar555
NOSE SCOOP - MONACO
NOSE SCOOP - CANADA
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
bar555
bar555
CHIMNEYS - TURKEY
CHIMNEYS - MONACO
CHIMNEYS - CANADA
scarbs
scarbs
393
Tomba’s right the more open sidepod\chimney is for the oil cooler, which is placed on only one side of the car. However the SECU and other large black boxes tend to be in the front of the sidepod. They are placed between the floor and the internal ducting from the sidepod inlet to the rad. Often the finned heatsink from the ECU is exposed inside the ducting, or a duct takes flow from the duct down to the ECU. There are some electronics inside the cockpit which sit along side the drivers hips (the monocoque is surprisingly wide at this point). Lastly the crash logger sits behind the seat or under the roll hoop. The stuff around the engie and gearbox although looking like ECUs (i.e. metal or carbon box with CAN connectors, wiring etc) tends to be wiring loom junction boxes or hydraulic valve blocks.
Scarbs
bar555
bar555
COCKPIT DETAIL
bar555
bar555
FRONT BRAKES - MONACO
The brake disc is not included
bar555
bar555
STEERING WHEEL - Image from Bahrain
STEERING WHEEL - Image from Canada
bar555
bar555
INDY FINS DETAILS (FLIP UPS)
bar555
bar555
REAR WING - MALAYSIA
REAR WING - BAHRAIN
REAR WING - SPAIN
bar555
bar555
REAR WING - TURKEY
REAR WING - MONACO
REAR WING - CANADA
bar555
bar555
DIFFUSER - VALENCIA JANUARY TESTING
DIFFUSER - BARCELONA FEBRUARY TESTING
DIFFUSER - BARCELONA APRIL TESTING
DIFFUSER - MONACO
DIFFUSER - CANADA
No visual change since winter testing
bar555
bar555
FRONT WING - MONACO
FRONT WING - CANADA
:arrow: http://www.f1technical.net/development/166
Conceptual
Conceptual
Is it me, or are the Monaco and Montreal wings identical? I cant spot any difference except the roundness of the top of the endplates, but that may be an illusion caused by the angle...
Chris
timbo
timbo
111
Seems same to me too!
That often comes to my mind when comparing present cars from cars from early/mid 90's - back when it was easy to tell what track type car setup is it, while today apart from some additional small details seems no difference at all (except form Monza).
I wonder how teams accomodate this difference between the tracks, however front end stability is paramount on both tracks. I remember from GP4 helper that front wing doesn't add much to the drag so if you able to control aero bias you can ran agressive front wing even in low-downforce configuraions.
bar555
bar555
R27 in 2007 had a completely different front wing (for lower levels of downforce) for Canada compared to the one used for Monaco .
R28 , on the contrary , used a front wing for higher levels of downforce for Canada ( :?: ) , which was very similar to the Monaco version
here is a comparison between R28's - R27's Canada and Monaco FW versions
:arrow: viewtopic.php?f=6&t=5131&start=20
