Ground Effect - Bring It Back
toraabe
toraabe
Re: Ground Effect - Bring It Back
Phillyred wrote:I would think with the current aero packages with the addition of side skirts or some way to increase ground effects cars should be able to follow closer leading to more passing.
You need venturi tunnels...
Pierce89
No. You don't. Venturi tunnels are no different to any other GE solution. The DF levels and balance change in turbulence or at different attitudes would be just as large as with a flat floor and diffuser + wings. F1 already performed wind tunnel tests and learned that circa 2006-7.
rjsa
rjsa
51
Care to point to the research?
