Mercedes W13
Re: Mercedes W13
PlatinumZealot wrote:
26 May 2022, 18:42
I think Vanja you will have to to adjust your Mercedes chassismodel a bit based on the new evidence we have that the Mercedes chassis is not that draggy, nor remarkably draggy compared to Ferrari or RedBull.
What evidence would that be? :) Being slower on straights with DRS off in the race? Both Ferrari (Barca RW) and Mercedes (Barca RW, among other novelties) demonstrated how easy it is to miss a DRS design for optimal speed boost, unlike RB. With a simple RW swap, they are all there or thereabout...
I asked dialtone for some data about top speeds, this was very detailed work and meticulous approach to exclude other factors from top speed comparison. Here they are
dialtone wrote:
26 May 2022, 19:55
with lap number:
LEC 17: 305 (haas in front)
VER 42: 305 (alpha tauri in front)
HAM 21: 304 (zhou in front)
PER 26: 307 (1-2s behind russel and verstappen)
RUS 24: 302 (fighting with Verstappen no tow)
SAI 39: 308 (I think he had bottas in front)
I don't know exactly the distance in front, I would need to write a more complicated script to deal with potential tow.
dialtone wrote:
26 May 2022, 20:09
Also not sure if you care about this, but this is 90%ile lap between 2-49 (which contains all the fastest laps found earlier):
https://i.imgur.com/LNYPbMH.jpeg
So 6 laps are going to be faster than this out of 66 and 60 laps are slower than this, I figure it's the easiest way to remove tow somehow although VER and PER spent many laps behind Russell.
LEC: 304
VER: 303
HAM: 301
PER: 305
RUS: 300
SAI: 307
While I had my suspicions about drag reduction of Bahrain vs launch spec sidepods, this comparison simply cements it - nothing suggests that this is a low-drag chassis. With different floor and minimized bouncing, unlike Bahrain, having a better car and less drag on RW and still a bit slower in race clears things up completely.
Not that I would choose launch spec sidepods if I was Mercedes, those wing mirrors are brilliant and they are certainly enhancing floor performance, maybe even RW as well. I've used this kind of stubby wing design (although around front wheels, so slightly different angles) to allow aggressive front wing use in some trials and experiments and it was a brilliant addition.
RZS10
359
Re: Mercedes W13
26 May 2022, 22:14
So we can safely say the Barcelona wing was a high downforce wing then.
I'm very sure the wing used in Barcelona was their launch spec wing just without any paint apart from the Petronas logo area (no black, no red, no silver), a wing which according to the team (source: Michael Schmidt who talked to Merc engineers) had high drag.
Re: Mercedes W13
RZS10 wrote:
26 May 2022, 22:31
26 May 2022, 22:14
https://i.imgur.com/LVjAl7P.png
Yup. I was alluding to the Monaco setup using that same wing as Barcelona. So since you mention now that the same wing was used at those tracks then yup, Mercedes was indeed running a higher rear DF setting at those tracks too. Probably to offset the loss of raising the car up in those races..
AeroDynamic
349
Re: Mercedes W13
michl420
michl420
19
Re: Mercedes W13
Looks like their sidepod cooler pass through under the fuel tank/monocoque. Bring COG vs. aero on the radar again.
pursue_one's
97
Re: Mercedes W13
SiLo
138
Re: Mercedes W13
RZS10 wrote:
26 May 2022, 22:31
26 May 2022, 22:14
It's the same except the edges of the top plane at the corners are a different shape.
Felipe Baby!
mantikos
mantikos
Re: Mercedes W13
26 May 2022, 22:43
RZS10 wrote:
26 May 2022, 22:31
26 May 2022, 22:14
And still somehow fastest in the speedtrap during quali iirc
restless
restless
Re: Mercedes W13
Severe bouncing in first training. In Monaco where speeds are not so high?!
Quantum
Re: Mercedes W13
restless wrote:
27 May 2022, 15:25
It was front suspension related, from both drivers. So not the same problem of porpoising.
The heave spring was changed on George's car during FP1, so might be a case of running too stiff.
"Interplay of triads"
Re: Mercedes W13
230
Re: Mercedes W13
why does it look like one of the exhaust pipes from the left cylinder bank swings over to the right manifold collector?
And possible one of the left ssings ovrr to the right?
Stu
Re: Mercedes W13
ringo wrote:
28 May 2022, 06:43
There were some other shots earlier in the year where it looks as though the exhaust turbine has at least three (but possibly up to six) entry ports into the turbo body.
Re: Mercedes W13
Hamiltonsay front downforce is great, but resr downforce is lacking in Monaco.
Could be that the side pod wing does not work well at low speeds? Or maybe the floor just needs more tweaking?
zibby43
zibby43
613
Re: Mercedes W13
28 May 2022, 22:41
It’s all the suspension, per Merc engineers. Gary Anderson agrees. I agree with him, which is scary.
