Matt Somers wrote:http://f1zoom.co.cc/?year=2012&race=spa ... 256&view=1
It's just a wear thing (can't embed it)
Renault R24 and the Minardi PS04 had similar features back in 2004.Crucial_Xtreme wrote:@Shelly or any of the other aero guys, can you explain how & why the vertical slot on the Williams RW is there & what it's doing to/for the air flow? If I'm not mistaken it's a one-off design for them as I don't recall any other team using such a design. Thanks in Advance.
Pic of RW
http://www.formule1.nl/media/uploads/me ... 1624.2.jpg
Thanks Shelly & Tozza. I thought maybe they provided a function similar to the louvers at the top but wasn't sure.Tozza Mazza wrote: Renault R24 and the Minardi PS04 had similar features back in 2004.
The way the wing and endplate interact 'pushes' the air in the centre of the wing towards the endplates. These profiles help bleed some of this, and reduce drag, especially at higher speeds. This is the same reason we get the little cut outs at the top of the end plates behind the profiles.
This is just based on what I have learnt myself, could be completely wrong.
Is that laser somehow connected with wheel slip sensor, or what is its purpose?Gridlock wrote:"Optimess" (and a laser warning symbol) on the yellow label: http://www.elag.com/
The tube visible in the rear of the floor will be the starter motor hole? Interesting rectangular slot surrounding it? Plenty of struts/braces around there for sure.
pretty sure not a single gram of PVC makes its way into a F1 wiring loom...You cannot judge from here what damage you got ..but fire extinguisher and water on open electical connections is sure not going to make the electrics and electronics guys happy.. and it´s remove and bin all that stuff to avoid further horror later in the season..but then, Bruno ..who cares...ESPImperium wrote:Chassis may be undamaged in a structural sence. However its the wiring looms and any wiring that may have been part of the chassis during the chassis layup that may not be in great shape. For example the PVC sheilding ans such may have melted in a pretty in accessable area and thus make the chassis a minor right-off.
This is Chassis 03 that Senna used. Williams still have Chassis 1 that did all but the last pre season test and the Mugello test. Chassis 2 was in Parc Ferme so they have enough cars to race.
