Ferrari SF21
TechF1
Re: Ferrari SF21
SiLo wrote:
20 May 2021, 14:14
TechF1 wrote:
20 May 2021, 13:56
Nothing particularly new, but so many spare parts :wink:
https://pbs.twimg.com/media/E1vW3R6WUAI ... name=large
Well it is Monaco, you're more likely to need them here! Does anyone know how the front cameras connect to whatever circuit they are part of? Only just clocked the knob like connectors for the front wing.
http://www.formula1-dictionary.net/tran ... amera.html
Re: Ferrari SF21
Is that a new floor or an optical illusion?
"Soft-Z" floor?
gordonthegun
254
Re: Ferrari SF21
Sevach wrote:
20 May 2021, 22:34
https://www.racefans.net/wp-content/upl ... -24-18.jpg
"Soft-Z" floor?
I think it's an optical effect, but I found this photo where there seems to be a kind of bridge on the floor in front of the rear wheels going from the more internal long fin to the small ones on the edge.
Here too, real or optical effect?
SiLo
138
Re: Ferrari SF21
TechF1 wrote:
20 May 2021, 19:30
SiLo wrote:
20 May 2021, 14:14
TechF1 wrote:
20 May 2021, 13:56
Well this is pretty cool
Felipe Baby!
LM10
LM10
121
Re: Ferrari SF21
Sevach wrote:
20 May 2021, 22:34
"Soft-Z" floor?
It does seem like one of the two new floors they've come up with until now.
I've gone back and checked. Ferrari introduced a new floor in Imola first:
And then in Portugal they introduced a bit of a refined version of that new floor:
From Barcelona on they've used one of those new floors, but I've not found a good quality picture to see exactly which of them, as both are pretty similar and only differ at the rear outer edge section.
Note: I've copied both pictures out of "aerofoilf1"'s comments. Shout-out to him.
gordonthegun
254
Re: Ferrari SF21
This floor:
seems different from this (the second "new" one):
In Racefans photo it seems that the fin on the slide stops before the end of it.
amr
amr
Re: Ferrari SF21
gordonthegun
254
Re: Ferrari SF21
amr wrote:
21 May 2021, 10:19
I can find any clear picture but from what I can see it looks to be the same floor
From the above pictures it seems the same, but from this...: :?:
amr
amr
Re: Ferrari SF21
My opinion is that the soft Z is just an illusion and you actually see the vertical fin hiding the sharp Z from that angle
f1316
f1316
82
Re: Ferrari SF21
Of course the floor they brought to Portimao was tested - to seemingly positive effect (each driver who had it outperformed the one who didn’t in free practice) - and then not raced, apparently due to only having one. The scuttlebutt at Barcelona was that they didn’t bring this new floor there due to not being suited to track characteristics.
All of which makes me wonder if either of the following are true:
a) it’s a high downforce but low efficiency solution (ie good for Monaco but not Barcelona)
b) the tests in Portimao gave more complex data than the pure lap times showed - ie they still needed to tweak the floor before introducing it and there just wasn’t time to do this before Barcelona
wowgr8
wowgr8
29
Re: Ferrari SF21
I read that the Portimao floor didn't produce the desired results so with budget cap in mind it was decided not to produce more than one and to shelve the floor for the time being
gordonthegun
254
Re: Ferrari SF21
I guess we have to convince ourselves that the car, at least externally, has no changes in Monaco and perhaps never or very little will have in this season. :cry:
ncx
ncx
19
Re: Ferrari SF21
SiLo wrote:
20 May 2021, 14:14
TechF1 wrote:
20 May 2021, 13:56
Maybe relevant to your question:
This is an Alpha Tauri front wing (couldn't find photos of a Ferrari wing with such view). It is visible on the left inside face of the cone what may be an electrical connector:
(pic from motorsport .com via @Morteza).
Within the Ferrari nose mount side there seems to be a corresponding connector:
(pic from AMuS),
more evident here, where a cable is attached:
(pic from a post by @zioture).
The wing, afaik, also has thermal sensors for the tyres and possibly other sensors, which probably use that connector.
Re: Ferrari SF21
http://www.gptoday.com/full_story/view/ ... in_Monaco/
Interesting read regarding Ferrari's pace...
SiLo
138
Re: Ferrari SF21
ncx wrote:
22 May 2021, 13:01
SiLo wrote:
20 May 2021, 14:14
TechF1 wrote:
20 May 2021, 13:56
https://cdn-1.motorsport.com/images/mgl ... -det-1.jpg
https://imgr1.auto-motor-und-sport.de/F ... 792416.jpg
(pic from AMuS),
https://pbs.twimg.com/media/Ewcva5CWQAA ... =4096x4096
Thanks! That clears that up quite nicely. I had never spotted the extra connector there on the inside.
Felipe Baby!
