dren wrote:Do the regulations call for a torque map of the power unit vs pedal position, or is it just the ICE? I think it's the power unit. That would take out a push KERS system.
5.5 Power unit torque control :
5.5.1 The only means by which the driver may control acceleration torque to the driven wheels is via a single chassis mounted foot (accelerator) pedal.
This is what the regulations says. This is what caused me to believe that the ERS activations must happen through the accelerator pedal and not via a push-button on the steering wheel.5.5.4 At any given engine speed the driver torque demand map must be monotonically increasing for an increase in accelerator pedal position..
So only a wet and a dry map is allowed.5.5.3 The accelerator pedal shaping map in the ECU may only be linked to the type of the tyres fitted to the car : one map for use with dry-weather tyres and one map for use with intermediate or wet-weather tyres.
Yes my thoughts exactly. These same rules apply this year, yet a kers push button and diverse kers settings are obviously allowed. I think those rules only apply on the engine.Dragonfly wrote:That doesn't prevent the possibility to adjust power output from the steering wheel to more aggressive (overtake) and less aggressive or conservative.
It says power unit. Not engine.turbof1 wrote:Yes my thoughts exactly. These same rules apply this year, yet a kers push button and diverse kers settings are obviously allowed. I think those rules only apply on the engine.Dragonfly wrote:That doesn't prevent the possibility to adjust power output from the steering wheel to more aggressive (overtake) and less aggressive or conservative.
I agree. Im also confused at the moment.Abarth wrote:5.5.1 clearly doesn't allow for push button.
As I understand 5.5.3, it seems even that you cannot have more than two maps.
Something which is not corresponding to some interviews and articles about the new cars. I don't get it, really.
This also removes the possibility of a kick-down device to activate the ERS.5.5.2 Designs which allow specific points along the accelerator pedal travel range to be identified by the driver or assist him to hold a position are not permitted.
Two maps for the throttle.Abarth wrote:5.5.1 clearly doesn't allow for push button.
So no kers push-button. And there will be different maps to choose from.Power can only be demanded by the pedal. Up until now the pedal provided engine power and button directly supplied kers power.
Next year the driver will get both solely from the pedal. However, the driver can select a map from the steering wheel that opens up maximum ers boost for overtaking, the button only selects the map, but the pedal demands the power. Its a subtle difference.
Can't store more than 4MJ.turbof1 wrote:Seems right to me. If there were no different mgu-k maps to choose from, the maximum of 4MJ wouldn't hold any value.
Question: is there a restriction on the amount of energy the teams can store for the mgu-k? If there aren't, cars could come with fully charged 12MJ batteries at the start.
Yes. It was also my original thought. But the answer I was looking for was the one about the button activated ERS.turbof1 wrote:Seems right to me. If there were no different mgu-k maps to choose from, the maximum of 4MJ wouldn't hold any value.
