2018 French Grand Prix, Le Castellet, June 22-24
flynfrog
Re: 2018 French Grand Prix, Le Castellet, June 22-24
dans79 wrote:
24 Jun 2018, 19:00
TwanV wrote:
24 Jun 2018, 18:54
What's the point, 5 or 10 seconds..
The point is that in general penalties are a complete joke now. Pretty much everything is a slap on the wrist compared to what you are getting away with.
What are you even getting at? Do you really want to black flag every car that locked up on the inside with cold tires and makes contact, pretty sure every driver on the grid has done it at least once before. You have spent multiple pages ranting what do you propose?
Of course..now it rains..
[media]https://twitter.com/AlbertFabrega/statu ... 3294520320[/media]
GPR-A duplicate2
64
flynfrog wrote:
24 Jun 2018, 19:15
dans79 wrote:
24 Jun 2018, 19:00
TwanV wrote:
24 Jun 2018, 18:54
When you have a driver who is carrying so many penalty points for the last couple years, surely that warrants bigger punishment, than the one used for drivers who aren't carrying any.
Sierra117
So apparently a water leak is the reason why Perez was retired (water leak that would have significantly affected cooling and therefore overheating damage to the engine), meaning no fault in the engine itself.
NIKI LAUDANZ SolidarityCubolligraphy | Instagram | Facebook
#Aerogorn & #Flowramir
GPR-A duplicate2
64
Sierra117 wrote:
24 Jun 2018, 19:21
Bottas suffered the same issue in P2.
JonoNic
GPR-A wrote:
Sierra117 wrote:
24 Jun 2018, 19:21
Can that be fixed without breaking the FIA seals?
Always find the gap then use it.
GPR-A duplicate2
64
JonoNic wrote:
24 Jun 2018, 19:24
GPR-A wrote:
Sierra117 wrote:
24 Jun 2018, 19:21
That is not related to PU and hence, should be able to fix it, just the way it was fixed for Bottas.
dans79
267
JonoNic wrote:
24 Jun 2018, 19:14
You are getting petty now. You initially wanted a black flag... Who was Vettel going to hurt in this ultra safe track?
flynfrog wrote:
24 Jun 2018, 19:15
Both of your are wrong. I said nothing about a black flag, that was a different member, see below.
maxxer wrote:
24 Jun 2018, 18:11
Your boy just loses control everytime when the pressure is on and tries to take out the whole field.
He needs to get a black flag and sit at home and watch a race maybe.
The in race penalty options are as follows in order of severity.
  1. 5 second time penalty
  2. 10 second time penalty
  3. Pit lane drive through penalty
  4. Pit lane drive through 5 second stop and go.
  5. Pit lane drive through 10 second stop and go.
  6. black flag
  7. banned form the next race
The only other penalty is a grid drop for the next race. The stewards are far to lax when it comes to penalizing drivers.
Drive through, and mandatory stop and go time penalties should be issued far more often to keep the drivers in check.
201 105 104 9 9 7
jz11
jz11
19
GPR-A wrote:
24 Jun 2018, 19:10
jz11 wrote:
24 Jun 2018, 18:42
GPR-A wrote:
24 Jun 2018, 18:28
Which rule books says that and when was the last time it happened?
he cut one corner by 50% and the next one 100%, he almost gained a lead, backed off not to, and slotted nicely into 2nd place avoiding possible scrap in couple corners - these are facts, if you don't see it that way, you're ignorant
now that being said - there is no way to measure the effect on the race, hence no penalties by stewards
that being said - things like these are supposed to be taken care of by the track itself - it is quite stupid when you can cut couple corners and accelerate while doing that - there were no polystyrene barriers, nothing at all - smooth tarmac actually, where he gained most
got lucky and got away with it this time, and all the blame has to be put on the people that configured the track
There has never been penalties for avoiding a crash and cutting corners, ON FIRST LAP. It will never happen either.
that is what I said - you can't judge that and assign a penalty, that is why track has to be configured as not to give an advantage to someone cutting the track so much, because the ones that do - do gain an advantage of not having to contend for space with others in those first critical corners after a start
polystyrene boards that make drivers wiggle around them are the perfect example of what should have been on that escape road, but there was nothing instead, so both Max and KMag went straight instead of even pretending to steer in a direction of that corner, KMag at least had the sense to give the gained time up, Max - not so much
maxxer
maxxer
Schuttelberg wrote:
24 Jun 2018, 18:40
maxxer wrote:
24 Jun 2018, 18:11
Schuttelberg wrote:
24 Jun 2018, 18:06
The hate on the forum is strong. It was undoubtably a poor effort from Seb on the first corner but was it any different to Bottas at Baku or Spain last year? I don't remember penalties being given that day and incorrectly so. Vettel got a fair penalty today.
I know. The guy needs to get a grip specially considering how he performed under pressure he had on him in 2010 and 2012 in the last race.
Yeah he is a great driver if he can keep his cool at the start we might have seen race between champions.
with the different tyre strategies and all.
F1NAC
170
dans79 wrote:
24 Jun 2018, 17:58
JonoNic wrote:
24 Jun 2018, 17:58
Hamilton commenting on 1st lap incident 🤣
It's true, penalty was complete BS.
Well he didnt complain when Max ruined seb's race... oh wait. Who benefited the most from that? What a hypocrite
TwanV
TwanV
jz11 wrote:
24 Jun 2018, 19:36
GPR-A wrote:
24 Jun 2018, 19:10
jz11 wrote:
24 Jun 2018, 18:42
What's your point jz? You'd rather have seb ruin both bottas' and verstappen's race? Ves didn't gain a place, didn't lose a place, didn't gain time, didn't lose time. Dunno what you're trying to say here except the obvious.
FrukostScones
162
Track was better then expected. VET a bit unlucky.
Clearly Vettel's fault but he tried to avoid it just couldn't, can we move on?
dans79
267
Wow, Max is still butt hurt about the press.
https://www.autosport.com/f1/news/13700 ... ttel-crash
201 105 104 9 9 7
