Mercedes AMG F1 W05
Re: Mercedes AMG F1 W05
Green light means ERS isn't fully charged and the Mechanics can work on the Car without their rubber Gloves.
zgred
Thanks Thunders.
Crucial_Xtreme
Crucial_Xtreme
404
Holm86 wrote:I cant see it creating downforce. To me it looks more like its diverting air downwards. The leading edge is much higher than the trailing edge.
The orientation of the two part wishbone looks to be helping in managing FW upwash but just the orientation of the two parts is going to create a bit of DF.
heimana
heimana
during this footage they had differents sidepods, less cooling for the engine
hollowBallistix
hollowBallistix
What are the silver bits located near the front wheels / suspensions arms ? they brake duct intakes or something else ?
Shakeman
Looked like taped up brake ducts.
andrewf1
So AMuS reports Rosberg saying that:
-the car, as expected, did show some problems (a huge list, actually) during testing, but that these things are normal, having been identified thanks to the amount of running they did in Jerez. Should be sorted out for the next test.
-the new brake-by-wire system is not sorted out yet, problems with the brake-balance
-vibrations at the back of the car, which should also be fixed
-not possible to judge the performance of the car, the Jerez test was purely a reliability test.
http://www.auto-motor-und-sport.de/form ... 29092.html
Add to that list Toto Wolff saying that although the cooling worked fine at Jerez, it could present an issue in Bahrain and you end up with some busy 2 weeks for the Merc engineers until the next test - but it should all be within plan.
Anon123
Anon123
andrewf1 wrote:So AMuS reports Rosberg saying that:
If Merc have a lot of problems then you wonder how many problems the other cars have and how many of them are yet to be found.
Juzh
161
andrewf1 wrote: Add to that list Toto Wolff saying that although the cooling worked fine at Jerez, it could present an issue in Bahrain and you end up with some busy 2 weeks for the Merc engineers until the next test - but it should all be within plan.
Bahrain's temperatures at this time are not even that high. It could be until malaysia that we'll actually see a true test for cooling.
http://www.timeanddate.com/weather/bahrain/manama
If you look at forecast for next 2 weeks, you can see it hardy goes past 20 degrees.
Richard
Richard
Anon123 wrote:If Merc have a lot of problems then you wonder how many problems the other cars have and how many of them are yet to be found.
The article does say it is normal to have a long list.
NewtonMeter
NewtonMeter
<snip>
From what I can tell, they seem pretty pleased - problems and all.
Nothing is foolproof to a sufficiently talented fool...
SectorOne
I would be more worried if they had no problems honestly.
NewtonMeter
NewtonMeter
SectorOne wrote:I would be more worried if they had no problems honestly.
Haha, if so, one would worry that they didn't try hard enough. :lol:
hollus
A look inside the sidepods, from Blackout's picture. Zoom and enhance!
Blackout wrote:Those pipes (exhaust pipes?) we se under the bodywork, and their location, look strange to me. And what are those silver things near the floor at each side of the gearbox?
http://www.formula1.com/wi/enlarge/0x0/ ... 1ja047.jpg
Rivals, not enemies.
bonjon1979
bonjon1979
30
hollus wrote:A look inside the sidepods, from Blackout's picture. Zoom and enhance!
http://imagizer.imageshack.us/v2/xq90/542/ilgr.png
Looks like the exhausts bending up to join with the turbo to me.
