Mercedes AMG F1 W07
RA168E
RA168E
Re: Mercedes AMG F1 W07
What could the damage to the gearbox have been? It was a side impact not a rearward? Did the hit on the side restrict cooling are or something in the side of it for the gearbox? What could it have been.
dans79
267
RA168E wrote:What could the damage to the gearbox have been? It was a side impact not a rearward? Did the hit on the side restrict cooling are or something in the side of it for the gearbox? What could it have been.
My guess would be the impact put a lot of axial load down the drive shaft!
201 105 104 9 9 7
giantfan10
giantfan10
27
Mercedes reported that it was not related to the accident with Bottas
from PlanetF1:
"Mercedes also revealed that the damage to the gearbox was not the result of his accident with Valtteri Bottas at Turn 1.
Despite that Hamilton says he has no concerns about Mercedes’ reliability."
Pressed as to what did cause the damage, he said: “It doesn’t really matter.”
Mr.G
34
I read somewhere that Nico suffered some engine issues at the end of FP1. Is there some confirmation?
skoop
skoop
Mr.G wrote:I read somewhere that Nico suffered some engine issues at the end of FP1. Is there some confirmation?
There's a short Story on AMuS on that subject.
I don't know if my translation is correct, but I read it as ignition Problems caused the engine to switch to an emergency programme. Everything could be solved for fp2.
http://www.auto-motor-und-sport.de/form ... 86254.html
Mr.G
34
Thanks, so no engine change.
De Jokke
How is this possible, all these testing miles with not a single problem.
Season starts and the problems start to pop up, first Nico in FP1 and now Lewis.
Didn't merc run the engine at full tilt in testing then? Would be strange to not do so...
Mercedes AMG + Hamilton => dreamteam!
If you can't beat'em, call Masi!
Ozan
Ozan
Hybrid system failed
De Jokke
Ozan wrote:Hybrid system failed
I know, but after all this testing, come on... ](*,)
3jawchuck
3jawchuck
37
Even in the times of unlimited testing failures happened.
Merc are maybe also pushing their technological development a bit harder to counter diminishing returns.
De Jokke
If he gets a new hybrid system, will he get penalised in Russia? Probably :|
Anyone knows if Lewis starts on softs or mediums? + wouldn't it be better to start from the pitlane (avoiding collisions)
giantfan10
giantfan10
27
De Jokke wrote:If he gets a new hybrid system, will he get penalised for Russia? Probably :|
Hamilton can start on whatever tire he wants....
De Jokke
Problem for @LewisHamilton has been identified as MGU-H issue. Team will put 2nd power unit of season in for race tomorrow. #skyf1
(will probably start from p-lane)
Mercedes :|
De Jokke
Ted Kravitz ‏@tedkravitz · 9m9 minutes ago
Latest from Merc: Lewis will start from the back of the grid with new power unit. LH had choice of pit lane start but wanted start on grid.
hurril
hurril
Why is there a need to start there? I thought that was only after exceeding five units per season?
