Mercedes AMG F1 W09 EQ Power+
wizzer
wizzer
Re: Mercedes AMG F1 W09 EQ Power+
PlatinumZealot wrote:
10 May 2018, 12:52
Zynerji wrote:
09 May 2018, 21:29
Why welded exhausts and not mandrel bent? :?: :?:
Bending that size pipe would be too much internals stresses. It would crack after a short time in the heat.
I agree, especialy with a very tigh radius like that but Inconel 3Dprints pretty well.
wizzer wrote:
10 May 2018, 15:52
I’m suprised they use pie cuts elbows for their exaust system and not a 3D printed piece as they used a pretty neat one in that area last season. There wasn’t an as dramatic change of direction than this year. That souldn’t be a game changer after the turbine but pie cuts does still create more turbulences. Looks like a bit of weird cost saving to me.
From my experience pie cuts vs madrel bend, there is literally zero difference in performance. Hell in even more critical areas such as valve seat angles you won't find much difference between radius or discreet angles.
A mechanic shaves the clearance between tyre and floor.
Note: the very flat angle of the pull rod and how high the rocker is relative to it. This keeps the pull rod clear of the floor for aero, even if the geometry/stiffness design is tricky.
Via @ScarbsTech
wizzer
wizzer
godlameroso wrote:
10 May 2018, 15:59
wizzer wrote:
10 May 2018, 15:52
There is in theory but very minimal to null I agree, even more with a turbo and after the turbine. I guess that's why they elected to save a buck on that.
ScrewCaptain27
577
FW main flaps have been reshaped:
Top view of the new flick on the suspension:
Wastegate pipe and microphone arrangement:
Note the exposed wheel tether.
All pictures via AMuS
- Serj Tankian
Ferraripilot
21
Hack and slash engineering with that flick atop the front top a-arm as I see it. That particular a-arm position with the wheel upright was one of their more unique features to the front suspension of this car. This addition tells me their new found flow in this area may be, to an extent, unwanted.
djones
djones
What would the microphone be used for?
pisangkacau
pisangkacau
djones wrote:
10 May 2018, 17:53
i think FOM experimenting the placement of the mic for better engine note
A little tip in the middle of the deflector.
dren
226
Looks like a lot of optimization rather than significant changes, additions.
Honda!
If there's something visually striking... It's hidden inside the garage.
dren
226
Sevach wrote:
10 May 2018, 18:53
Hamilton probably got a hair cut.
Honda!
mantikos
mantikos
Ferraripilot wrote:
10 May 2018, 17:50
Sure doesn't look like that to me, they had a similar suspension last year, this is just further refinement of the out wash flow structure keeping the tyre wake away.
ScrewCaptain27
577
Impressive detail shots by Scarbs:
- Serj Tankian
Too little visual upgrades so far, they'll bring them out tomorrow.
