Mercedes AMG F1 W07
diego.liv
diego.liv
Re: Mercedes AMG F1 W07
Evolution of brake duct area since Melbourne
http://it.motorsport.com/f1/news/merced ... ca-732821/
Mark4211
92
Mercedes front wing picture, posted by their FB page
SiLo
138
This car is a work of art. No other car on the grid has anything close to the technical body parts as this.
Felipe Baby!
mycadcae
This process is what made..so please explain . tq
Regard,
Nik Wan, Mechanical Designer, CATIA V5/ Solidworks/Autodesk Inventor/ AutoCAD
mantikos
mantikos
mycadcae wrote:http://s32.postimg.org/7khh9kgut/image.jpg
I am not sure what you mean "this process is made"
I am guessing you're asking what's going on.
The person in the picture is using a UV flash light also colloquially referred to as a blacklight to cause the viz-flo to glow florescent and taking a picture of the patterns. Merc is using a UV reacting viz-flo paint - makes it harder to just take a regular pic with regular light and see the flow patterns so no competitors can see it either.
mycadcae
Can use computer simulation in UV flash?.
Regard,
Mark4211
92
Mercedes seem to have the softest damper stiffness compared to most teams on the grid, but still have performance
https://vimeo.com/165344465 (17:00)
The low front wishbones are a big contributor there - look at them versus the Williams for example.
honda_fun
honda_fun
36
https://youtu.be/hZjJsArhFYo?t=69
https://youtu.be/Gm7YA3p8TJI?t=118
When comparing Rosberg and Verstappen in sector3 in RUSSIAN GP circuit,
The front suspention of W07 was well stroke and rosberg steering smooth.
But which of Toro Rrosso ST11 was seen so stiff for me and was very few suspension stroke,
so that in sector3 of the circuit, Verstappen had handle more his stearing.
I think the suspention of Mercedes W07 was innovative.
A tire grips it well on any road surface, and height of car is kept, too.
When possible somebody teach me, the mechanism of front suspension of Mercedes W07.
Mark4211
92
honda_fun wrote:https://youtu.be/hZjJsArhFYo?t=69
Like what I've posted above, in this video https://vimeo.com/165344465 at 17:00 in, notice that when Hamilton goes over the 'bumpy chicane', only his outside front suspension bounces instead of the inside one.
+ Mercedes are known to run with very soft springs/dampers and anti-roll bars, however - if anti-roll bars are very soft, the usual thing that will happen is inner suspension will bounce/extend toward the ground, but in Mercedes' case, it does not.
What I'm inferring from Mercedes' suspension is that the inside suspensions are "pushed down" and loaded, instead of the usual unloading/extending downwards, on the inside.
i.e. When they turn left, both the usual outside suspension is loaded, as well as their inner suspension.
Here's an example of what I'm trying to say.
https://streamable.com/i131 - AbuDhabi 2015, then Russia 2016
Watch the inner suspension (apex suspension). It is stiff as hell. BUT it gets the most extension and bounce when it is the outer suspension (non-apex)
flickerf1
flickerf1
The Wicked + The Divine.
I embedded the images
Also from Scarbs
Mercedes front turning vanes from below
diego.liv
diego.liv
Front config usually closed, different config of the small bottles ( :?: ) to help the s-duct(S) reach the upper surface of the car
http://images.adrivo.com/images/950/q_8 ... 739995.jpg
atlantis
atlantis
21
