Development to the last minute possible is the way to go, you want to make sure you don't leave any stone unturnedPlatinumZealot wrote:McLaren have not started their engine yet much less receieved it. Believe it or not this is good news. The sakura warriors are still tweaking out to the last detail before machining those last bits.. And no. My sources are not in my head.
Hypothetically, could Mclaren run the old PU (2016 last spec) on the first test just to check AERO correlation and then use the new PU at the second test? I know that the PU configuration will be different (size, design ect) but as far as I know the mounting points of the PU are standardized by FIA so it should not be that difficult to do it right?
But from another hand you want to see how the car (suspension, aero, tyres ect) behave with the new engine under acceleration & braking so going this route has its own pros and cons obviously.
Just a thought anyway
