Mercedes AMG F1 W09 EQ Power+
cplchanb
cplchanb
Re: Mercedes AMG F1 W09 EQ Power+
i wonder if merc has any plans to install aero devices on their halo. them and rb are the only teams not to have anything on the thongs.
PlatinumZealot wrote:
18 May 2018, 06:26
Thunder wrote:
15 May 2018, 12:19
JPBD1990 wrote:
15 May 2018, 10:54
Could just be the angle/lighting...
It's real.
https://twitter.com/AlbertFabrega/statu ... 4261682177
Meh. Just another level of advertising. Its the new fad that's going on now: 3D decals. Blackberry in this case.
Except Blackberry is 7 lumps in a 2, 3, 2 arrangement. The Mercedes is 6 in a 3, 3 configuration.
Sorry, but you don't stick half a dozen big VGs on the sidepods as an advertising gimmick. Weak thinking on your part, I'm afraid. Try harder next time.
You got me!
On a serious note, these fins are quite interesting. Very sharp edged and an air-foil shape in plan view.
SparkyAMG
cplchanb wrote:
18 May 2018, 19:51
Are you sure about that? Both Mercedes and Red Bull have halos with sections that are more wing-like in profile, they're just fully integrated into the halo like they've been moulded on, and not added on like everyone else has done.
Edit: having looked more closely at other teams I'm not so sure now... I'd always thought the halo was pretty much round in profile but perhaps I'm wrong.
LM10
LM10
121
SparkyAMG wrote:
19 May 2018, 08:27
cplchanb wrote:
18 May 2018, 19:51
I'm not sure, but I can imagine that the halo itself must be identical on every car. Don't think moulding would be allowed. Just adding extra elements.
roon
roon
412
Correct. The halo is a spec component supplied to the teams by the FIA's supplier. Round tubing with a +20mm (30mm?) free section around the surfaces of the halo for bespoke fairings.
Here's what one looks like painted, no fairings:
Just_a_fan wrote:
19 May 2018, 10:16
djos
113
LM10 wrote:
19 May 2018, 08:47
SparkyAMG wrote:
19 May 2018, 08:27
cplchanb wrote:
18 May 2018, 19:51
Mercedes and RedBull both have a sculpted aero shroud around their halos, no other teams do this.
Personally I think the FIA should have excluded anything other than a fully enclosed fairing / shroud as all the little winglets etc make the halo look even worse. The Merc and RBR solutions look far better.
"In downforce we trust"
pimpwerx
pimpwerx
dans79 wrote:
17 May 2018, 20:49
I assumed they are using them to try and get some flow from atop the sidepods to roll over the edge and eventually feed the top of the diffuser.
Thanks to you, drens, Wesley and anyone else who responded. That makes sense. After my post, i considered the AoA of the fins and realized they probably weren't angled enough to adequately select the air. I suppose the idea that it helps keep the flow attached (or at least directed towards the diffuser) is true, but the vortexes do a better job since the sidepods in that area aren't long enough for the air to stay properly attached. So spinning it off at those points let's them control it better. Is my thinking wrong there?
djos wrote:
19 May 2018, 09:00
Haas also had this design but Grosjean debuted a winglet style design in Barcelona.
Some Posts have been moved to the McLaren Team Thread. (No, that's no Typo. ;) )
So they are definitely gonna use the VGs on the sidepods
What is that in his hands? An instruction on how to install them?
dren
226
Looks like it might show which VG goes where.
Honda!
Webber2011
Webber2011
dren wrote:
23 May 2018, 13:28
Or, he could just be the bloke putting the decals on 😂
F1Krof
94
The paper is a 2D mold profile controller. You can observe that the VGs have different profile and different curve indentations, since it is very subtle to spot with a naked eye and very easy to fit them in wrong order, they use these paper molds.
Wroom wroom
How are they stuck on top of the sidepod? Ductape?
