2014 Design
slimfitcasual
Re: 2014 Design
aleks_ader wrote:I think it goes for minimum crosssection. But team will opt very narow minimalistic version beacuse aero benefits...
Assuming it passes crash tests correct?
Per ardua ad astra
Re: 2014 Design
They probably will; they already get longitudinal flat noses through; latitudinal flat noses shouldn't be that much more a problem.
Kiril Varbanov
147
Re: 2014 Design
Now that Piola sent out his render, I think I'm coming late to the party, but it was sitting the draft folder for quite some time:
F1 2014 rules illustrated.
The model is done by Will Tyson and I just followed the trendy yellow :) Enjoy, like and comment.
aleks_ader
90
Re: 2014 Design
turbof1 wrote:They probably will; they already get longitudinal flat noses through; latitudinal flat noses shouldn't be that much more a problem.
Yes that i also considered. It is AERO vs. Structural part. How team will work out we will see soon than later.
gray41
Re: 2014 Design
I was thinking the new noses could have a slight upward flick to them like the GP3 design.
Obviously within the box allowed, could we see something like this from anyone?
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
theWPTformula
50
Re: 2014 Design
gray41 wrote:I was thinking the new noses could have a slight upward flick to them like the GP3 design.
http://andyyoungf1.files.wordpress.com/ ... am_gp3.jpg
Yes, as long as the cross section stays the same up to 250mm above the reference plane. ie the bottom has to flick up with it.
FW17
169
Re: 2014 Design
Since vanity panels are allowed and scarbs illustration is also allowed, what is stopping the nose cone from looking like this?
Light green vanity panel
Dark green splitter
Re: 2014 Design
Why would you do that? I don't see the benefit of that Solution.
Edit: I hope this will be the most represented Design:
Lycoming
Lycoming
106
Re: 2014 Design
WilliamsF1 wrote:https://pbs.twimg.com/media/BZmspvyCIAAtT5g.png
http://i1267.photobucket.com/albums/jj5 ... 9d5364.jpg
Dark green splitter
Probably the fact that it provides no benefit. Think first about why they want a high nose. Hint: It has to do with the underside, not the top side.
Re: 2014 Design
The idea is interesting.
If properly modelled, a vanity panel could scope under air that would otherwise travel over the nose and guide it underneath it. It wouldn't be a big gain, but it would atleast be something.
Holm86
247
Re: 2014 Design
As far as I know vanity panels may have no aerodynamic function what so ever.
variante
138
Re: 2014 Design
Holm86 wrote:As far as I know vanity panels may have no aerodynamic function what so ever.
Actually, they have an aerodynamic function only (if you take away aesthetics)
WilliamsF1 wrote:Since vanity panels are allowed and scarbs illustration is also allowed, what is stopping the nose cone from looking like this?
It'll be interesting to see what shapes the teams will come out with, and some of them may actually choose an extreme solution like yours. However there are a few limitations to that: nose height limitations (see the scheme at page 28), which apply to vanity panels as well, and some more drag to deal with, for instance.
Re: 2014 Design
It's actually the front bulkhead that applies to the height of the vanity panel.
Holm86
247
Re: 2014 Design
[youtube]http://www.youtube.com/watch?v=rEza9TSq4IY[/youtube]
Some interesting talks. But go to 15:15 for the more 2014 relevant talk.
FW17
169
Re: 2014 Design
The image sketched is not very clear but it was supposed to have the idea of this
