2017-2020 Aerodynamic Regulations Thread
PABLOEING
PABLOEING
Re: Proposed 2017 F1 Aerodynamic Changes
FrukostScones wrote:
that looks pretty accurate imo. But not eye-pleasing.
the side pods won't be that fat imo.
and nose will still have penis extension if possible reg. wise.
Yeah, the sidepods are way out width-wise.
rjsa
rjsa
51
Rear of the car is completely undeveloped in that picture. this is far from what we'll see come melbourne.
New rules usually render undeveloped cars:
SR71
Yeah Mercedes proved you need the phallic extension to win WCC's.
zac510
zac510
22
I hadn't noticed that the rear wheels are quite a bit closer to the rear wing end plate. I suppose they will want to maximise the end plate size at its foot, to keep wheel turbulence out of the diffuser areas (if the rules allow).
467
zac510 wrote:I hadn't noticed that the rear wheels are quite a bit closer to the rear wing end plate. I suppose they will want to maximise the end plate size at its foot, to keep wheel turbulence out of the diffuser areas (if the rules allow).
The rear wing is 250mm wider (1000mm vs 750mm). It was narrowed in 2009.
Formula Wrong
Mercedes' Solution is just one of several possible solutions. For most other Teams that extension seems to work perfectly.
If you no longer go for the space someone always has to leave, you're no longer a racing driver
zac510
zac510
22
Yeah I remember that - I'm just trying to remind myself of the aerodynamic consequenses! It's an area that's been heavily developed with the 'brake ducts' and the vented rear wing end plates. It's hard to imagine the vented end plates existing in proximity to the moving wheel.
FrukostScones
162
Merc could built shortest possible 85cm in classic design and pass crash test. No need for extension.
RicME85
52
People completely missing the sarcasm from SR71.
FS - you claimed that cars won't look like the Perrin as they will all go for the finger nose, SR71 pointed out that won't necessarily be the case, Mercedes went a different way and have won everything.
FrukostScones
162
RicME85 wrote:People completely missing the sarcasm from SR71.
And why Merc could go different route? They can afford xxx crashtests and not 1 like Sauber in 2015.
And sarcsm is something else. :arrow: :arrow:
RicME85
52
Ferrari, McLaren and Red Bull all could do something different. A finger nose isn't a given
FrukostScones
162
RicME85 wrote:Ferrari, McLaren and Red Bull all could do something different. A finger nose isn't a given
yeah, banana shape maybe :mrgreen:
edit: I just wanted to say: Expect no beautiful fully noseScones. (not even on the Merc)
aleks_ader
90
Yeah with more "volumetric" work of diffuzer and underfloor that could change. Even nostrils could be very good way to accieve aka. high nose effect. Engineers will not forget what they learn from couple years back.
Even for low budget teams is probably better to use old knowledge that will provide them lowered the cost of initial evaluation of all possibilities in this new rules. Just for first year, play safe. And then make for 2018 overall overview what bigger teams find out.
But with that approach you somewhat negated the Brawn miracle, but in my opinion that is not possible anymore. There are no affective loopholes? Right? I believe.
henry
324
There may well be loopholes and there discovery probably won't rely on funding. My recollection is that double diffuser was initially recognised by two low funded teams, Williams and Super Aguri, and one with lots of money, Toyota. The Super Aguri idea was developed with Honda money before being passed to Brawn to earn the rewards.
On the likely form of the nose I think we may well see the return of Walrus Tusks, with existing nose designs, no doubt refined, and flying buttresses reaching forward 200 mm to pick up the neutral section of the wing. As you say feeding the larger diffuser is likely to be a priority.
As mentioned in this thread before the regs published on 29 April 2016 have a conflict in section 3.7.3 between the definition of the leading edge of the bodywork, the arrow, and the neutral profile drawing, drawing 7. My interpretation is that it is not possible to create a legal wing-and-nose to these requirements. Maybe this, or a clarification, might yield a loophole.
