ISLAMATRON wrote:WhiteBlue wrote:A central hit on the visor would have probably been less dangerous. Those visors are bullet proof. The edge is probably the weakest point of that structure.
doubt it, that would have been the worst place, straight on at the visor would have been disastrous, might be bulletproof(doubt that too) but it ain't spring proof.
Yes but bullets are also designed to penetrate something. Springs are blunt, they have rounded edges on the coils and flat tops and bottoms. So it might have been better, or worse to have hit only the visor. We don't know unless they test it. But to think a spring is more dangerous just because it's bigger than a bullet is foolish, bullets are pointy for a reason. And the fact that it took an impact from a spring and didn't shatter on the edges shows that it is indeed 'spring proof'.
RacingManiac wrote:
Assuming the 800g spring hits Massa with a relative speed of 290kph(as if the spring is stationary and the car travels at 290kph), it exerts something like 250J or energy....consider a .22LR bullet has about 150J, a 9mm has about 500J, the hit is not insignificant.....
Again, bullets are pointy, springs are not. Not saying it isn't a significant impact it very much was obviously, but they test with sharp objects because they focus all the energy in a small area.
ISLAMATRON wrote:the explosion in an exploding bolt can easily be self contained, it wouldn't even have to blow off the canopy like in a jet, but merely release the canopy.
That is a very very bad idea. Those can be accidentally set off by a mechanic in the pits, and for cripes sake it's an explosive! You cannot have them in a closed environment without an disproportionate increase in risk. What if it was tripped on the race track and you have a canopy either flying through the air or laying on the track around a blind corner.
Why increase the risk for miniscule gain?!? It makes no sense. I'll go back to what I said in another thread, why put a FOD screen on a passenger jet engine and increase your risk of it coming loose and going into an engine to prevent a very small risk of a bird strike? With that screen over the engine during all times it is operating, you have increased the risk of something being ingested to takeoff and landing to whenever the engine is running.
It makes absolutely no sense whatsoever. What if the canopy got stuck and the car was on fire? Since we are talking about the very rare happening here, that's a very valid thing to point out.
Giblet wrote:What if the drivers helmets had a steel cage like a hockey mask in front of the mask? Might look goofy, but Massa would only have a bent cage right now, and maybe a concussion, but likely no injury to his face.
Again, you're adding another element of risk to the equation. What if an object hit said cage and it dislodged from the helmet and it pierced the visor? What if it came detached after an impact and ended up on the track and another car hit it, flattened a tire and the car hit the barrier?
TheMinister wrote:The canopy could be made so perhaps it was one really strong roll bar (to protect driver from other cars) and the rest a bit weaker, so it would shatter in an impact like todays, dissipating some energy and deflecting any objects. It could also have quite an aerodynamic advantage, getting rid of the imperfections in the airflow the cockpit and driver cause.
Ask yourself if you would get in a car, that had a windshield that was
designed to completely shatter upon impact with an object. Why in the world would you even entertain that idea?!? If that car flipped and the drivers visor popped open and then that canopy shattered it would easily get in his eyes. I just don't get how that could even be thought of as a solution.
All these ideas floating around only increase risk, nothing but knee jerk reactions to an age old problem. I don't have an answer, but I do know that none of these being tossed out are good ones.
