2014 Design
Huntresa
Huntresa
Re: 2014 Design
Neno wrote:
Blackout wrote:But bigger how ? larger (bigger frontal area) ? larger but undercut ? larger with no undercut (like 2002-2003 cars for example) ?
higher ? longer ?
The removal of the beam wing and the exhaust exits* might, IMO, encourage some teams to sacrifice airflow above the sidpods and add air intakes similar to the Benetton B189
http://www.f1fanatic.co.uk/wp-content/u ... t_1990.jpg
I can only say Lambo 291. With today tehnology, i dont expect car with bulk sidepods, just few teams today run similar sidepods. Today car's have big wheelbase, so i expect similar packaging like today, Sauber will probably go for something like this.
http://www.racingmodels.com/ekmps/shops ... 4413-p.jpg
https://encrypted-tbn0.gstatic.com/imag ... rioKw9yZlw
We prob wont get smaller sidepods, especially not since Newey said they will prob be bigger casue they will house more stuff
Re: 2014 Design
Edit
rjsa
rjsa
51
Re: 2014 Design
Cool video from FIA on the side impact absorbing structures
http://vimeo.com/68370832
Re: 2014 Design
Video on Vimeo:
New F1 Side Impact System
24.06.2013 | New F1 Side Impact System
The FIA Institute has been working with Formula One teams to develop a new side impact system that will be on all cars next season
When the Formula One cars line up on the grid for the first race next season, few will realise that one of the biggest safety developments in recent years has taken place under their bodywork. Peel back the sidepods, though, and you will see that every car is sporting a new advanced side impact protection system.
It is the result of a year-long collaboration between the FIA Institute and F1 teams to develop a side impact system that works effectively, regardless of the angle of impact.
FIA Institute research consultant Andy Mellor, who led the project, explains: "We went back to basics to examine what a side impact structure really needs to do in different types of accident. We used Robert Kubica's crash in Montreal as a specific reference point since that was a major impact at an acute angle."
The current side impact system deploys crushable tube structures attached to the side of the chassis. Although extremely effective during normal impacts, they can break off during oblique impacts due to the extremely high tangential forces that are generated during the first few milliseconds of an impact. So Mellor engaged with the F1 teams to help develop solutions to the problem. Marussia, McLaren, Mercedes and Red Bull Racing each stepped forward.
Initial testing benchmarked performance of current structures using a new dynamic oblique impact test configuration. The core R&D then investigated two discrete options in parallel: optimised carbon tubes and crushable carbon sandwich panels. The latter comprised a variety of energy absorbing filler materials including foams, aluminium honeycombs and carbon honeycombs.
The testing concluded that the carbon tubes had far more potential to provide an efficient, lightweight and robust solution, able to manage impact loads effectively in both lateral and for-aft directions. The panels, in comparison, were surprisingly inefficient.
The winning solution was based on an initial design by Marussia, before undergoing extremely detailed optimisation by Red Bull Racing – an evolution of the current system, but using high-performance carbon fibre with a very bespoke external and internal geometry and precise layup configuration.
Paul Monaghan, Head of Car Engineering at Red Bull Racing, explains: "There were three teams that ultimately submitted impact devices that were subjected to a physical test, and ours was deemed to be the best of the bunch, so we pursued that device further."
The solution is a pair of structures fitted to each side of the car that do not shatter on impact but progressively crush and decelerate the car in a very controlled manner. During testing, the pair of structures were able to absorb nearly 40kJ of energy in both normal and oblique impact directions – a major advancement over current designs. In order to achieve this, the structures must develop huge forces; over 15 tonnes squeezing the chassis and 11 tonnes trying to tear the structure off the chassis.
The teams agreed to implement this system for 2014 at the F1 Technical Working Group meeting on 17 May 2013. At the same time, the technical requirements for mounting the structures to the chassis were defined, in order to ensure compatibility with all cars whilst providing the teams with a large degree of design freedom. Now it is up to each team to decide precisely how best to incorporate it into the design of their cars from 2014 onwards.
Monaghan says: "The tube has a common specification but how teams put it into their cars is entirely their business. The static tests that will be undertaken on the monocoque will determine the strength of the mounts and make sure that they are sufficient to support the tube. After that, it's down to the teams as to how they integrate it and how they design their car around it."
What is certain is that the new system will further improve safety while at the same time reducing costs for the teams. "One of the driving forces for this was to spare teams extra expense in the testing process," explains Monaghan. "Assuming everybody has a monocoque which is strong enough and passes the static tests, then they've saved money, as they're not doing an impact test. It should be a cheaper solution."
Monaghan adds that working with the FIA Institute on this project was "very easy, very straightforward" and he is delighted with the results. As he puts it: "We have a good solution, based upon sensible and sound engineering with some pretty good rationale behind it."
Re: 2014 Design
Ah damn, you beat me to it :P.
Looks like it will take the same room as the current structure.
Joie de vivre
Re: 2014 Design
Has anyone already made a sketch what next years cars will look like?
Huntresa
Huntresa
Re: 2014 Design
Joie de vivre wrote:Has anyone already made a sketch what next years cars will look like?
There is a sketch just above your post on this page 7, and on page 3 a sketch over the nose height.
otbsti
Re: 2014 Design
I'm hoping for the sake of cars looking a bit different, and for aero reasons, that some teams try to get rid of the airbox snorkel and revert back to a roll hoop like the MP4/4. That would be nice!
"Winning is the most important. Everything is consequence of that."
-Ayrton Senna
Mercedes AMG Petronas
Lewis Hamilton #44
Huntresa
Huntresa
Re: 2014 Design
otbsti wrote:I'm hoping for the sake of cars looking a bit different, and for aero reasons, that some teams try to get rid of the airbox snorkel and revert back to a roll hoop like the MP4/4. That would be nice!
I thought the airbox snorkel is mandated to be that height ?
matt21
86
Re: 2014 Design
It is mandated that the air intake is at least 200mm above the reference plane.
But to me it makes no sense to relocate the intake, because with the small ram effect you can enhance the efficency of the compressor.
And wit the turbo located at the center axis it would request air ducting which inmpedes losses.
Saribro
Saribro
Re: 2014 Design
And you need to have a certain surface in lateral view too. So you'll end up with a 'fin' anyway.
Re: 2014 Design
Wasnt the intake regulated to be around the cars centre line? if not you could indeed do some fancy things and still end up with the ram effect.
Teams might want to squash the intake lower, or not on the cnetreline to improve flow to the rearwing. You still get a blade and a fin(which isnt much of a problem) but the intake isnt in the way of the rear wing anymore. This could bring some gains with the loss of the beam wing.
RB7ate9
RB7ate9
Re: 2014 Design
From here at F1tech.
Based on the above photo (which does look like the turbo engine stuffed into an RB9), it looks like the exhausts extend well out from the centerline. Considering that there's no use for any "coanda" extensions, could there be a possible ability to shape the sidepods to have a lifting body effect? Something that could be construed as an exension rathe than a grpund effect item?
something akin to:
of course, please let me know if there are any regulations against this.
Huntresa
Huntresa
Re: 2014 Design
Yeah i think Renault customers especially newey will redesign the exhaust etc to make it as minimalistic as possible.
Also what do you mean by lifting ? An F1 car doesnt want lift or dont you mean lift in that way?
Huntresa
Huntresa
Re: 2014 Design
