Mercedes AMG F1 W06
Re: Mercedes AMG F1 W06
You mean old nose.. The one without the bulge was used first IIRC.
PlatinumZealot wrote:You mean old nose.. The one without the bulge was used first IIRC.
This is from the pre-season, it always had a bulge/belly, until now.
Belly might still be the same as launch.(camera angle). But now i think this new one is wider?
George-Jung
George-Jung
Could someone point out the difference.. I cannot see it :oops:
i70q7m7ghw
i70q7m7ghw
49
George-Jung wrote:Could someone point out the difference.. I cannot see it :oops:
Sevach wrote:Image
The tip no longer has the little carbon bulb underneath, the tip also appears to have been re-profiled.
Silent Storm
Silent Storm
111
The cheapest sort of pride is national pride, every miserable fool who has nothing at all of which he can be proud adopts, as a last resource, pride in the nation to which he belongs; thus reimbursing himself for his own inferiority.
SectorOne
Scarbs saying itยดs the same nose and underside.
Looks different to me though.
dans79
267
SectorOne wrote:Scarbs saying itยดs the same nose and underside.
Looks different to me as well, less bulge on the tip & the underside.
201 105 104 9 9 7
OO7
OO7
171
It is definitely a different nose.
Also Mercedes had tightened the rear packaging around the exhaust and cooling exits:
Spanish GP:
Austrian GP:
It looks again like Mercedes have copied the solution Red Bull were using a few races ago.
Blaze1 wrote:It is definitely a different nose.
Spanish GP:
Austrian GP:
If you mean tightening the bodywork they have at least three different engine covers with different degree of opening that they try as early as winter testing each year. Hot tracks use the ones with the bigger openings and cool tracks such as Austria will use the covers with the smaller openings.
OO7
OO7
171
PlatinumZealot wrote:If you mean tightening the bodywork they have at least three different engine covers with different degree of opening that they try as early as winter testing each year. Hot tracks use the ones with the bigger openings and cool tracks such as Austria will use the covers with the smaller openings.
The version used in Spain and a few other races was the tightest version, with the Monaco spec being more open, to offer additional cooling. The spec in Austria is a new development and is tighter than all previous versions. I believe it is a further refinement of Spanish spec.
The paint seems to extend a little further around the tip, which gives the illusion that the nose has changed.
McMrocks
McMrocks
32
Is it still a engine cover or is it already a beam wing?
OO7
OO7
171
It is a Lotus style nose. The previous iteration had a rounded bulge underneath, while the current version has a uniform horizontal section, more akin to an inverted ramp. I also think the new nose is ever so slightly wider.
atanatizante
115
Since Canada they have a new front brake fin, having an unique shape :
And the story is here : http://www.formula1.com/content/fom-web ... t-fin.html
On Sky Ted Kravits said they have here a 3rd engine or PU spec ...
Isn't the same engine/PU from Canada?
Isn't about their 2nd engine/PU without tokens but with some updates which could be classified reliability upgrades?
So how come?
Jesus
