*censored myself*
Anyway, what concerns your idea about that nose cone, it's about what I was thinking a few days ago in this thread:
viewtopic.php?t=1102
If anyone want to compare with the real C24, see here:
viewtopic.php?t=1107
From an aerodynamic point of view to have the supports behind the wing, being it the front wing or the rear wing, isn’t clever, because they would cross the wake, and that could and probably would affect the wing a lot more than the interference caused by two vertical plates attached directly to the wing (being them on the upper or in the lower side).ZE.FT. wrote: What I was personally trying to explain for the FIA/GT back wing mounts was to take again L shaped connecting plates but turn the L upside down to make the horizontal line of the letter L connect to the wing from the back edge onto the chord means to the top of the wing and then down to the bodywork.
This should increase downforce at the rear wing for FIA/GT and BTCC/WTCC cars. Not so sure about DTM,as I remember having seen back wing mounts there which came close to those which I have described
If we really have to trust them (do you exclude it was just a polite answer to a fan ?), Sauber until a couple of years ago already had two vertical plates, on the sides of the tub, behind the wing, the keels. Maybe they just attached the horizontal mounts to the keel or to a prolongation of the keel on the nosecone.ZE.FT wrote: Anyway we have to trust Saubers aero departments statement as mentioned that they have already tried drop plates which were behind the FW but found out that they did not add downforce.
FIA GT rules on the rear wing does specify the dimensions of a box, the rear wing assembly (that includes, wing, endplates and vertical supports) must be contained in that box, and it’s required that the box doesn’t protrude beyond the rearmost point of the car.ZE.FT wrote: Not so sure about 'the rules do not allow bodywork behind the rear edge of the car' for FIA/GT class.if you meant so.You will have noticed the huge diffuser dimensions which are well behind the rear edge of the cars.
