Another Movable Aerodynamic Device?
weisler
weisler
I saw this picture of the Ferrari at Imola, zoomed in and discovered that the element attached to the wheel, looks to be of a wing shape. Doesn't this constitute as a movable aerodymanic device?
What are your thoughts?
[IMG:152:132]http://img205.imageshack.us/img205/5814 ... wm1.th.jpg[/img]
manchild
manchild
They are considered to be ducts. Both Ferrari and Renault had them since last year. It moves same way as main duct so if untill man duct is legal so are these additional ducts (unless one of them generates downforce).
F2005
Renault has similar additional duct only below main duct and shaped differently
R25
RACKITUP
RACKITUP
"It moves same way as main duct so if untill man duct is legal so are these additional ducts (unless one of them generates downforce). "
Can you please explain again in English please, I dont quite you, or the concept of how these would work
Thanks
rkp
(woohoo! finished my damn dissertation! :D)
manchild
manchild
sorry, that was typo - man = main and one "L" and one "if" extra
It moves same way as main duct so until main duct is legal so are these additional ducts (unless one of them generates downforce).
I tried to say that ducts are not limited by number but by dimension. There could be much greater number tiny ducts on each wheel and as long as they are in compliance with FIA imposed dimensions and shape they are legal. When I wrote "unless one of them generates downforce" I had in mind the one used on Ferrari whose shape and position cause doubts about the legality since it appears that they might generate downforce.
BTW, that was not much better than my English (which is not my first language).
RACKITUP wrote:Can you please explain again in English please, I dont quite you, or the concept of how these would work
Repeated word, punctuation, missing word, punctuation.
ackzsel
Behold, the wrath of Manchild :twisted:
manchild
manchild
No no, no wrath, just sarcastic joke :wink:
jgredline
To finish first, first you must finish.
vyselegend
And one again, FIA rejected the complaints and declared the rear wing legal.
kilcoo316
kilcoo316
21
vyselegend wrote:And one again, FIA rejected the complaints and declared the rear wing legal.
If it passes the tests its legal.
Honda can cry and complain if they want, it doesn't make a difference. They should worry about designing their own car to go as fast as it can within the rules, and quit crying when someone else has done it better than them.
