Hi all,
really caught Le Mans fever this year and was wondering if anyone happened to know a high-ish quality video of an onboard lap of the le mans circuit? Ta Tom
You are correct It is from a f-en awesome video called Incar 956.RacingManiac wrote:Thats not a 917 BTW, the car clearly is turbo(which the Le Mans 917 never was), and the track has Porsche curves instead of the Maison Blanche as it was in the 70s, and the cars it passed were group C cars.....
Its probably a 956 or 962....
But it certainly will greatly compromise the car's handling......they could've achieve that same effect with the clutch-type diff with preload....or even a viscous type diff...dumrick wrote:I've heard that they used it having in mind that, this way, if a shaft failed in an endurance race, they would have traction to bring the car to the pits...RacingManiac wrote:I still can't believe Porsche uses locked diff for both 956 and 962.....
