Well, yes and no, Belatti: a flat patch is the english term for an alignment platform, the usual tool to setup a
chassis with precision.
You don't follow exactly the same procedure used to align the wheels of a regular car, altough you can use it for camber/caster and other wheel alignments, if you wish. At my local autodrome there is a shop that offers the tool. They are more or less affordable, it's not a "stratospheric" tool. I've seen (at e-bay) relatively cheap, used flat patches that allow you to weigh each corner, and ones with laser beams for alignment, they are more expensive.
I've seen them also being used at the Brazilian and Spanish GP by FIA officials to check the chassis regulations (floor clearances and the such).
I've
heard of people attaching solid wheels when using the platform at Indycar, Formula One and Formula 3/3000, but I've never
seen them, or, if they actually use them for regulations checking (it seems logical), I didn't realize it at the time I saw them.
Finally, I used to have (until it broke) a "Bosch card" with laser
ride height sensors: they
used to be cheaper and better suited to that particular task. I heartily recommend them. They are pretty practical for simulations and setups. This is a "repost":
Accesible simulations: nice reading
For Bosch software (WinDarab, for ECU tuning, and LapSim for riding height and speed simulation), check here:
http://www.bosch-motorsport.com/content ... l/3589.htm
The documentation is here (WinDarab):
http://www.bosch-motorsport.com/content ... Manual.pdf
And here (LapSim):
http://www.bosch-motorsport.com/content ... mV2007.pdf
Bosch ride height sensor: now they cost 2000 dollars (1190 euros) but you could buy them for 300 some years ago.
If someone has a good pic of a flat patch, please, be so kind. The one I posted is not at the level of this forum...
