I was wondering...
If oil gets thinner (i.e. less viscosity) over time, will it allow an engine to produce more power due to less resistance?
Or does oil actually get thicker and the reverse is true?
Probably something as thin as water. Looking at the state of some of the used oil that I see, I'd say it's thicker as one of its jobs is to collect all of the crap that accumulates as well as cooling and lubricating.adam2007 wrote:whats the oil number they use in f1 engine?
i mean my car is 15/30
Not stupid ray, you're fundamentally correct. But when oil is inside an engine, how can you guarantee the oil does not pass through a location where it overheats? Not a lot, but just a bit of degradation. Oil flows all over the cylinder head, and if some collects on top of a combustion chamber, some of it may have overheated.Ray wrote:I thought that oil doesn't degrade as long as you keep it within it's temp limits? I know they have additives, but if it doesn't degrade if you don't overheat it you could reuse it again right? After a good filtering of course. Or am I being my usual stupid self?
5/30 fully synthetic is the thinnest we use.ISLAMATRON wrote:do you guys use a zero weight Russ?
high oil capacity? plus they burn alot off and just add more... but 75K seems extreme, I'm gonna ask a couple truck mechs I know to find out.Ray wrote:How do the 18 wheelers here in the US get away with running their engine oils for so long? I'ver heard something along the lines of 75k miles. Is that true and if so how?
