Let me try..Never did work on composites.. but I like approaching the random problem, Kreus.
The wing takes the load across the span like a beam right? So I think the strength of the fibre needs to be mainly along the span of the wing than the chord.
When I see pictures of the inside of air plane wings they also have sections inside to strengthen it (Ribs?). So You would make multiple wing Ribs along the span. Of course the ribs are shaped like the wing profile. [Imagine bending the wing.. the top fibre is in compression and the bottom in tension.. the carbon fibre at the bottom i feel is supposed to be thicker because the main attribute of CF is it's tensile strength. Whether or not a spar is necessary you have to do some calculation or simulation. (Spar at the leading edge of the wing?)
Manufacturing.. I never fabricated anything from carbon before but from watching Youtube
.. you have to make a split mold to put in carbon fabric. I know in F1 they use pre-impregnated Carbon Fibre for this.
I don't know if you glue on the rib sections on the Carbon in the mold then Vacuum bag, then chuck them all into the autoclave at once.. or if there is a certain order to do it:?: Something must can be figured out. Just improvise.
That is how I would approach it. Even if It was the wrong way to do it, I still think it would hold up even if the deflection was too much for F1 standards. Then again, you can't really do much since it's just a small project anyway.
