raymondu999 wrote:another question though - are tyre heating and working inherently linked? We seem to have the mercedes,and red bull, for example. the bull just eats its tyres and heats them. Merc sometimes have tyre heatup problems, but can preserve the tyres for ages. Is it possible to work it in a way which makes sure the tyres are heated, but not worn quickly, and especially, kept in the working temps? Or are the two inherently linked so teams must reach a compromise?
I´m not sure that Merc is preserving the tyres or the drivers by not pushing is making them last...
Heat is the enemy of the Tyre the hotter it gets the quicker it detoriates.Simple experiment:
put 3 degrees of toe in your tyres and drive along.You will have quick has hell soaring temps in your tyres without even turning a corner.So tyre temp is not necessarily a function of pushing ,if you have a bit too much compliance in your suspension this will also raise tyre temps ,as does a certain ways of tuning the dampers does raise or lower tyre temps.
To my understanding it is very hard to be quick and still have low tyre temps ,the
holy grail is to get the tire to working as quick as possible without overheating them then in the stint.
