Silver bullet No.57- Floor edge wings and suspension tuning
The keener watchers among you may notice that RedBull's long floor edge wings have been adopted by other teams for the 2023 season. These floor edge wings are critical in making and keeping downforce when cornering. They are effectively side skirts and their purpose is to seal the floor while maintaining favourable air flow conditions near the floor edge at all times. They do this by staying parallel as are pressed against the road, their mounts flexing to deform the edge-wing just the right amount.
My hypothesis is the floor edge wing works critically with a hard front suspension and a soft rear as at the rear it must rest on the ground to seal approximately at the centre of pressure, but at the front of the floor the vanes must still be high enough to allow air to out-wash. The engineers must find the best combination of front and rear suspension setting to achieve this parallel seal when the car is cornering - not a trivial matter.
The springs on the floor edge seal is also critical here. The longer the floor edge wing the more conforming the seal is to the road, and the softer each spring/fence/swan neck on the edge wing can be made. The other benefit of the long edge wing is that it collects the outwash from the side pods better.
I believe the floor edge wings are probably the most important element on the floor, and they absolutely require a complex level of suspension tuning to unlock the prodigious levels of down-force they can provide. If the fact that Andrea Stella commented on them as very important elements isn't convincing enough, look how Mercedes adopted the design of the edge-wing and suspension to mimic RedBull's. We will truly see the improvement in corner exit speeds once Mercedes heads to Barcelona.
☄️ Myth of the five suns. ☄️
LxVxFxHxN
Hoffman900
Hoffman900
200
Re: Silver bullet No.57- Floor edge wings and suspension tuning
PlatinumZealot wrote:
30 May 2023, 02:33
Well first, keep in mind the strakes are really vortex generators, as seen on CART / Indy Cars in the 1990s when they weren't allowed barge boards:
Lola
Reynard
Other photos:
Professor Joseph Katz outlined how they worked in a 2002 SAE paper titled "Aerodynamic Effects of Indy Car Components
https://www.researchgate.net/publicatio ... Components
A generic, Indy-type, open-wheel, racecar model was tested in a low speed, fixed ground wind tunnel. The elevated ground plane method was selected for the road simulation since one of the objectives was to allow flow visualization under the car (and this is not possible with current rolling ground wind tunnel setups). Consequently, both the groundplane and the wind tunnel floor were transparent to facilitate the flow visualization under the vehicle. The aerodynamic loads were measured by a six-component balance, and an effort was made to quantify the partial contributions of the various vehicle components. The main trends and aerodynamic interactions measured with this setup appear to be similar to data measured in larger wind tunnels using rolling ground simulations. As expected, the two wings and the underbody vortex generators generated most of the aerodynamic downforce. The very small rear diffusers allowed by the new millennium regulations are less effective than before, and their contribution to vehicle downforce is quite small. In terms of the drag force, the main contributors are the four large wheels, the two wings and the body's downforce induced drag.
They essentially act as under floor barge boards. You can see how these VG's were placed in the previous era:
To quote Prof Katz from Aerodynamics of Race Cars
https://www.researchgate.net/publicatio ... _race_cars
Add-ons: vortex generators, spoilers, etc. In this section we discuss simple modifications that can be added to an existing car to increase downforce. One of the
simplest add-ons is the vortex generator (VG). VGs were used for many years on
aircraft, mainly to control boundary-layer flows. The size of VGs in such applications
was on the order of the local boundary-layer thickness, and apart from influencing
boundary-layer transition, they served to delay the flow separation on a wing’s suction
side. The use of such devices in automotive racing is quite different. Here the focus is
on creating a stable and long-tip vortex, which in turn can reduce the pressure along
its trail. A simple option is to add VGs at the front of the underbody and the long
vortex trails of the VGs can induce low pressure under the vehicle. This principle is
widely used for open-wheel race cars (e.g., Indy), and a typical integration of such
VGs into the vehicle underbody is shown in Figure 13. In such an application the
VG is much taller than the local boundary-layer thickness and the objective is to
create a strong and stable vortex which, as noted, can generate suction loads along its
trail. The principle was extensively used with delta winged aircraft at high angle of
attack (Polhamus 1971), but when the wing surface was not at high angle of attack, the
interest was mostly diminished (see, for example, Buchholz & Tso 2000). A generic
study of these VGs mounted to flat plates was reported by Garcia & Katz (2003), and
the results of a similar study, but with the actual shape of the race car underbody (as in
Figure 13), was reported earlier by Katz & Garcia (2002). The combined downforce
and drag results for the two underbody shapes is presented in Figure 14. Note that in
the case of a flat plate the VGs were placed below the plate and ground clearance was
measured from the lowest point of the VG to the ground. In the Indy-type underbody case the VGs were flush with the immediately following body’s lower surface and ground clearance was measured from the vehicle’s or the VG’s lower surface. Also, for the data in Figure 14 the VGs were oriented at 20-deg yaw, and results for
additional shapes and yaw angles are presented by Katz & Garcia (2002). The downforce data in Figure 14, in general, increases as the ground clearance is reduced. The basic flat plate will have the lowest drag and no downforce. The curved Indy car underbody, but without the VGs, does generate downforce, even far from the ground, because of its effective thickness and camber. As ground proximity is reduced, downforce increases for this configuration, along with the associated drag as shown in Figure 14. When two VGs per side were added to both models, the downforce and drag increments were similar and large. Flow visualizations with these models indicate that with reduced ground clearance not only does vortex strength seem to increase but the two vortices per side untangle and get closer to the vehicle’s surface (e.g., increasing suction force). This increase in vortex strength and the reduced distance from the underbody (of the vortex) explain the increase in both lift and drag as ground clearance is reduced. At the very low ground clearance values however, a maximum in the downforce is reached due to possible breakdown effects
in the trailing vortices.
Willem Toet even confirmed they are not sealing the floors in his most recent publicly available lecture. Think about, how do you seal a floor that has a very low pressure distribution underneath of it (much lower than anything outside of the floor)? You can listen to his lecture here: https://www.youtube.com/live/kixMMfEQ-FA?feature=share
You can see the vortices from the VG’s (“strakes”) and the vortex drawing inward from in front of the rear wheel at the 14:00 mark (CFD created by Kyle's Engineers for Willem). The whole lecture is worth watching, but Willem states that the current floors aren't sealed like you think. Also watch the slice at .25x speed at the 15:00 mark. So essentially, my understanding is the strakes create a large powerful vortex that is fed supplemental vortices from engineered leaks in the floor. You can see from Prof. Katz's work just how big of a difference they make. A lot of people are looking at them (and the floor) as if flow under the floor is laminar, when everything suggest that it isn't.
Same thing Prof. Katz is showing here:
and as seen here (viewtopic.php?p=1115962#p1115962)
and I suspect the vorticies is probably most important at about where the pitot tubes take a reading here:
Image but you can also see the flow-vis flowing to the floor edge.
While I think there is merit to your theory, the fact these cars still stay on the road while running over curbs suggest to me they aren't as sensitive to ride height on the floor edge as you may suggest. Look at the Df figures from Willem's example of a 1970s design with sliding skirts and how much the Df levels change without them. My hunch is running over curbs would provide a similar momentarily loss of DF as that gap opens up. To quote Prof Katz who adds merit to that:
By the end of the 1980s this method was used in many forms of racing,
resulting in downforce values exceeding the weight of the vehicle (Wright 1983).
However, the sliding seals at the vehicle sides were not trouble free. Irregularities
in the road surface occasionally resulted in seal failure and the immediate loss of
downforce with catastrophic consequences. The effect of increasing the gap between
the ground and the seal on the downforce is shown in Figure 10 (from Wright 1983),
and a 20-millimeter (mm) gap could result in the loss of 50% downforce. This led to
the banning of all sliding seals by 1983, and in most forms of racing the only part of
the vehicle allowed to be in contact with the ground are the tires.
While I believe the floor edge is very significant to performance, and limiting inward flow where you don't want it is crucial, I don't believe it's the "silver bullet" you're hoping it is, and if anything, they do not want the floor to seal entirely (see Kyle’s video on the RB19).
However, this does suggest it is something RB is working on:
(assuming the cornering load is the same between shots)
I think all this shows that these are both drawn incorrectly though:
and the vortex is like it is in the Willem video as modeled by Kyle, and runs down the tunnel and is fed by other vortices, which Prof. Katz also states. Latios's CFD shows the same thing: viewtopic.php?t=30734
30 May 2023, 02:33
Floor vortex sealing is a bit of a semantics deception. You have strakes at the front generating a powerful vortex structure along the edge of the floor that keeps the suction along the edge for a while. This suction generates local lateral flow outboard that prevents the dirty air entering that specific part of the floor.
The edge wing very likely has some mechanical compliance that provides a bit more mechanical sealing (but only in terms of reducing the gap between the edge and the ground, not completely sealing off the edge) especially while cornering. I don't think it's too big though, we still have stricter floor flexing tests. Naturally, this refers to the outboard edge in the corner and it would be a very unstable and unpredictable situation if you were to completely seal off the floor mechanically. This would lead to a massive and unpredictable downforce increase on the outboard side of the car, generating a massive CoP shift and could even potentially lead to a stall in a portion of the floor. I haven't seen RB edge wing touch the ground for an extended time and have only seen it scrape the kerbs. Just remember how unpredictable the W13 was with zeropods and rear corner of the floor flapping and sealing unexpectedly.
On the other hand, edge wing feeds this vortex structure with air from the top of the floor, re-energising it for a bit more umpf. That's the additional aerodynamic sealing. This is to my best understanding of the topic.
The real silver bullet with these cars might be rear tyre squirt management, to avoid unexpected df losses mid corner... Or it really might be down to the best possible integration of floor performance in the range of ride heights and integration with suspension.
Andi76
Andi76
405
Vanja #66 wrote:
30 May 2023, 08:25
30 May 2023, 02:33
As far as the sealing of the floors is concerned, there is unfortunately still a widespread opinion (thanks to the media) that the goal is to seal the floor completely to the sides. But this is not the case and not the goal. As far as I understand it and it was explained to me, the floors are surrounded with suction, but not completely sealed and in the area of the floor edge wings vortices are generated which flow to the main diffuser and there help to increase the extraction potential of the diffuser and to keep the tire squirt away. The stronger and more stable these vortices are and the better you can position them, the better in terms of diffuser performance and stable downforce. Some teams have problems here, especially in terms of stability and positioning of these vortices, which has a negative effect on the balance, especially in the rear. At least that's how it was explained to me. The ride height has a strong influence here, since the vector field of the vortices changes when they become elliptical (which must be a particular problem with "low roof" floors, which would explain the advantage of Red Bull's "high roof" or short throat and why this way was chosen). At least that's how it was explained to me.
jjn9128
771
30 May 2023, 02:33
The keenest watchers amongst you would have noticed Red Bull didn't have an edge wing (in the sense the FIA envisioned) until this year, but lots of teams had one last year. Red Bull had an ice skate - which many teams both last year and this copied.
But you're obviously right, an edge wing is key to bortex sealing of the floor. That and their 1500% anti-dive front suspension, 2500% anti-squat rear suspension, and septuple DRS is what's making them unbeatable this year.
#aerogandalf
Hoffman900
Hoffman900
200
Forgot to add an update to my post:
While nothing is exactly the same, the physics still apply.
Honda’s 2009 Technical Review on their Third Generation Activities:
https://www.f1-forecast.com/pdf/F1-File ... 2e_all.pdf
Starting on Page 157 they discuss the effects of the sidepod undercut on floor sealing.
Also great discussion on yaw and tire squirt (and difference between brands) earlier, and their attempts to measure it.
Looks like the theory rang true then.
LxVxFxHxN
Stu
Hoffman900 wrote:
20 Jul 2023, 23:50
Thank you for that, what an awesome document!
If Honda were aware in 2009 (and previously), I wonder how it became lost knowledge to most tech squads in the pit lane?
I find an interesting symmetry in the shape of the sidepods compared to the previous rule set. Previously, the successful designs had the sidepod at the front with lots of rear floor exposed. Now, the successful design is exactly the other way round - lots of exposed floor at the front (in the form of the very long undercut below the sidepod entry) and little exposed floor at the rear.
The RB19's undercut is almost an inverse of the W11's sidepod shape.
Not a technical insight, just an aesthetic one. :lol:
I can see why Mercedes went the way they did with a downwash design - based on a car that didn't porpoise - but sadly porpoising is real and their design didn't work with the suspension technology allowed. Lots of downwash with a floor that is close to the ground equals lots of floor "sealing". But it doesn't work well enough outside of that limited parameter.
Farnborough
Farnborough
91
Just_a_fan wrote:
21 Jul 2023, 11:04
It's an interesting comparison. I feel the front end sidepod appeared to co-exist with an absolute forest of barge board elements, all managing the flow to move outward and downstream into whichever rear strategy the team employed.
Ultimately that barge board function now transferred rearward and underfloor in its location, this seems to then have need to manage upper front air volume (rear of top front wing plane, further along tub etc) with this scrolling undercut to move that outwards in separate function to the lower level floor entrance via strakes etc.
This naturally "asks" for sidepod internal volume to be now displaced up and rearwards to allow those two/primary outwash to be accomplished.
