What "exactly" is Lift? (or Downforce)
Vyssion
Moderator / Writer
I made mention of making some kind of post about this in one of the other aero threads, and interest of a handful of people was piqued... so here we go!! It's kind of been one of those things that, when I first looked into it, I was somewhat surprised that there was so much going on, when all we kind of imagine is "big pressure on one side, small pressure on other side = make wing move" or something...
I've lifted the bulk of this out of my "Aero CFD Bible" notebooks I've kept over the years (hence some of the sketches and equation images included below). I think this one was a bit of an amalgamation of a... quorra answer I read once...? Plus some of my own understanding mixed in with it, and whatnot.
Just a small note, I find it a little easier to think in terms of "lift" rather than downforce, so I'll stick to this throughout the post... but the same applies, just in reverse.
Aerodynamic Forces Definition
So... first of all, lift is only one part of the aerodynamic force in a system. It's the component of aero force vectors acting all over a body, which point "normal" (or perpendicular) to the direction of airflow. Since any aircraft (or F1 car) will distort the local flow around itself, in an ideal situation, you'd want to figure out that direction at an infinite distance away from the thing; where the air is undisturbed. The other (main) component is drag. Similar to lift, it's defined as the component of aero force vectors acting all over a body which point parallel to the direction of airflow.
"Aerodynamic Forces", as a collective term, are defined as the sum of all local pressures (or force vectors over a given area) which act orthogonally (at a right angle) on the local surface of a body; and the shear forces, which act parallel to the local surface.
Aerodynamics vs. Electrical Engineering
When aerodynamics was first researched into, electrical fields were relatively "new"... and after a few very smart people poked around at the maths and physics behind them, they figured out that those same equations which helped to calcualte electromagnetic field forces could actually be somewhat adapted and then used to explain / calculate aerodynamic forces. This is why in the field of "potential flow theory", you still see terms like "source and sink" used to describe the theoretical model components that make up an aerodynamic calculation. Personally, I don't find electrical engineering interesting at all; day one of electrics 101 at uni saw my uni professor state "electrons go this way... but because one guy made a mistake 500 years ago, we go the other way... and we didn't bother fixing it".
That confusion continues (at least in my opinion heh...) up to the point where these sources and sinks and the mathematics behind them are actually quite complicated and difficult to work with, and not too easy to learn. So as all good engineers (and teachers for that matter) do when something is complicated, we simplify!! Unfortunately, they were mostly too simple and in some cases, just plain wrong... and that kept on being the case for quite a few decades.
Anyways, enough backstory for now, let's move on to the mechanisms at play here:
Molecules and Maths
don't freak out, this maths is friendly :D
If we look at things on a molecular level, every air molecule is in a dynamic equilibrium between a few different effects: inertial, pressure, and viscous.
  • Inertial, means that the mass of the particle wants to keep moving just as it did before, and you'd need a force to act on it in order to change it
  • Pressure, means that the air molecules oscillate all the time and bounce into one another; the more bouncing, the more force they exert on their surroundings
  • Viscosity, means that air molecules tend to assume the speed and direction of their neighbouring particles, because of that oscillation stated above
All three of these "contributions" are contained within that fancy scary looking equation up there; they can be mathematically expressed. What's improving as time goes on, is our ability to solve these kinds of equations. However, for most turbulent flows, the characteristic length of those turbulent mixing eddies is so small that it is practically impossible to solve those equations fully.
Flow over the Upper Surface of the Wing
When a wing moves at subsonic speeds, the low pressure area on the upper surface kind of "sucks" in air ahead of it. If we pick some random packet of air for a moment, then as it's travelling towards this wing, then the other air packets above itself, and downstream of itself, there will be "less bouncing around of molecules" because they are being drawn towards this region of low pressure, and so most of their movement will tend in that direction, instead of all around the place; which would imply a lower pressure. Conversely, the air packets below our special chosen one won't have their "bouncing around" diminished, and this has the effect of pushing our packet of air upwards (since it's now higher pressure than the air above our packet) and towards the wing. So our packet (I feel like I'm using "packet" wayyyy too much here now...) will rise and accelerate towards the wing and be sucked up into that low pressure area above the wing.
As the packet accelerates, it gets stretched out lengthways. It's pressure will also drop proportionally to the increase in speed it undergoes, and because it's stretching lengthways, it's also made to contract orthogonally -- it gets thinner. Think of how you'd stretch a lacky band; as you pull it longer, it gets thinner.
As this is all going on, our packet moving over the aerofoil profile suddenly finds that the wing surface below it is curving away from it. If the packet was to keep going in the same direction, then in the "space between it and the wing", there'd almost be like a mini-vaccuum going on. And so, reluctantly (remember, the packet of air has a mass, and therefore an inertia!!) it will change course and follow the contour of the wing profile.
The fast-flowing, low-pressure air will then (in turn) suck on a new air packet ahead of it and below it. This will cause a decelleration and a slight "recovery in pressure" over the second half of the wing's surface. And so the packet has changed direction. Keep that going, and you can get some pretty amazing direction changes... I mentioned in the other post about how adverse pressure gradients, laminar, and turbulent boundary layers work, so I'll just link to that here if you wanna go read up on it: viewtopic.php?p=1055271#p1055271
I think it's pretty intuitive once you've read the above paragraphs, but just in case, lift can only be generated if the upper surface of the wing slopes downwards and away from the initial path of that air packet, once it's navigated around the leading edge. You can accompolish this either by using camber, or increasing the angle of attack of the wing. However, since camber allows for a more gradual change over the surface, it tends to be more efficient than simply increasing angle of attack.
Flow over the Lower Surface of the Wing
A packet of air which ends up below the wing, will experience less uplift and acceleration than one on the upper side. Also, in the convex part of a highly cambered aerofoil, it will experience a little bit of compression. Even so, it too has to change it's flow direction, because the cambered aerofoils (or angled ones) will push the air below it downwards, creating more pressure and additional "bouncing around" as the packets run into each other. When the packets reach the trailing edge of the aerofoil, they have picked up some downward speed because of this.
Behind the wing, the packets of air continue along their now "changed" (i.e. downward) direction for a short while due to their inertia; and as they do so, they push the air around them downward and sidewards. Above them, the air which has already been pushed sideways before will now move to "fill the void" left by the other packets. Zoom out far enough, this motion looks like two large vortices that have been shed from the surface.
Explained in Several Equivalent Ways
Looking at the sketch above, one of the ways lift is generated can be expressed as the "delta" (or difference) in pressure between the upper and lower surface of the aerofoil. In terms of molecular "bouncing", the molecules will bounce against the lower side more than the upper.
Or, you could look at a more zoomed out picture: A certain mass has been accelerated downwards by the wing. This required a force to be acted on that mass of air, and it is the reaction of that force in an equal and opposite direction which is lift.
If you were to look at the wing as some kind of "black box" which you only knew what went in, and what came out -- but not what was going on in the middle bit -- the packet of air going in gets some kind of downward "knock" to it, which it reacts with an upward "knock" to the wing, as it exits the black box. In this example, the two paragraphs above explaining what lift is at a molecular level vs. at a macroscopic level would be indistinguishable from one another.
It should be noted that most of this change in direction happens in the first like 30% of the chord of the aerofoil, and not right at the trailing edge.
Additionally, the common-sense assumption about these pressure differentials is that when you want to "make lift", you just increase the pressure below the wing. The reality is that most of your pressure differential between the aerofoil surfaces actually comes from the pressure drop on the suction side of a wing, and not the other way around.
So I guess there is a little bit of deflection... a little induced flow direction change... but of suction... bit of bouncing around... bit of hitting into other things... bit of Newton going on... bit of "off the surface" antics happening... and who knows what else? But one thing is for sure: there's more than one mechanism at play.
Supersonic Flow
When an aircraft moves faster than pressure changes can propogate through the air around it, the changes in pressure we just talked about are no longer smooht, but sudden. The aircraft will "push" the air molecules aside, producing a compression shockwave. Behind thhe "front" of that shockwave the pressure, temperature, and density are higher than that in front of it; and the delta between them is proportional to the local change in flow direction.
Bear with me for a minute here... this maths is a little scary, but it doesn't bite :)
The incremental pressure change due to the body hitting air with an incremental angle, expressed in terms of undisturbed (i.e. freestream air) flow, is proportional to the change in streamlines:
Gas pressure on a molecular level is the number, and severity, of particle collisions. The air molecules experience more collisions on the downstream side of the shockwave, since air pressure is higher there. The average direction of those extra collisions is orthogonal to the shock wave because this is the point at which normally-moving air particules suddenly get kicked, jerked, and shoved by the shockwave front. Once a molecule crosses this shockwave, the collisions come from all directions and so any further acceleration is stopped dead in its tracks. If the surface curves away from the local flow direction, the air produces an "expansion fan" which resets the old pressure and density values when the air again returns to it's original direction.
Pure supersonic lift is a matter of "angle of incidence", and basically nothing else. Any local curvature of the wing aerofoil profile will not change overall lift (but it will increase drag). In this case, the total aerodynamic force is normal to the wing, and so drag will also become proportional to the angle of incidence and any extra surface curvature. In hypersonic flow, which is a little out of my usual aerodynamics knowledge trove hah, you basically just use "impact theory", coined by the venerable Isaac Newton.
Separated Flow
Increasing pressure is roughly the same idea as increasing it's potential energy, which leads to a reduction in kinetic energy (from the dynamic pressure portion of the total pressure equation) and therefore an overall average decceleration of the flow.
Since the air right down on the surface, well within the boundary layer, is travelling slower, it is more affected by the adverse pressure gradient serving to deccelerate the flow. And if you continue to deccelerate, meaning over time you're slowing down the average airspeed in that region, you will eventually slow down enough that your velocity hits zero (and then negative). At that point, you're flow is "stalled" or "separated".
Turbulent boundary layers can withstand greater adverse pressure gradients because they have "mixing" within them; rather than laminar layers... so there is energy transport within the boundary "layers". Meaning that the air on the surface, just like with a laminar boundary layer, gets mixed up this time with a bit of higher energy air.
As such, it takes a larger upwind increase in static pressure in order to overcome that mixing effect, slow down the airflow velocity, and then stall the boundary layer. This is why vortex generators are a thing at all; it's because they promote that mixing in the boundary layer by forcing vortical flow regimes at a small enough scale so that they increase the boundary layers ability to withstand the increasing static pressure in the direction it travels (the adverse pressure gradient), which keeps the boundary layer attached for longer: a beneficial effect.
Separated flows remain the only real part of aerodynamics which cannot be precisely predicted, even though its effects are quite well understood. It will still produce lift, but less than that of attached flow (aside from a veeeeeeeery narrow portion of the operating limit where a smidge of trailing edge separation gets you a small net increase in lift if done just right).
Delta Wing Lift
A very specific form of lift generation dominated by flow separation and vortex shape control (with secondary and tertiary vortices too), whilst trying to not cause the vortices to burst. Usually this is referred to as "vortex lift", and it can be quite powerful when used correctly -- particularly at the more supersonic regions of flight.
Is this the End...?
Yup! That's all folks! :D
(there's probably a bunch of stuff I've missed but ah well... c'est la vie)
#aerosaruman
SiLo
135
Re: What "exactly" is Lift? (or Downforce)
Excellent write up once again.
Can you explain how a small amount of flow separation at the trailing edge of a wing can increase the overall pressure above/below it?
Felipe Baby!
SmallSoldier
SmallSoldier
473
I have to admit I had to read it a couple of times, but it made a lot of sense! Really appreciate the effort to keep it in simple terms for us mere mortals :)
hollus
SiLo wrote:
21 Apr 2022, 00:08
My guess us that it becomes a mini Gurney flap, a fence to be jumped over, but it is just a guess.
Rivals, not enemies.
SiLo
135
hollus wrote:
21 Apr 2022, 09:30
SiLo wrote:
21 Apr 2022, 00:08
That makes sense, I guess if you can induce that it means you could run without a gurney flap. Would that potentially be more efficient I wonder?
Felipe Baby!
621
btw
the 'Gurney flap' wasn't patentable .....
because it had been previously invented and patented c.1932 by some German chap
but DSG seems to have invented cold fuel (at Kyalami 1967)
isn't lift like propeller action ? ....
for some a viscosity-dominant process ... for others a momentum-dominant process
jjn9128
770
Tommy Cookers wrote:
21 Apr 2022, 12:31
btw
One of my favourite quotes on the Gurney flap comes from Enrico Benzing's wings/ali book. About it originally being called a "Nolder" a term [paraphrasing] "even the British are unable to find the provenance for".
#aerogandalf
dialtone
dialtone
110
What is the typical size of contribution to the lift equation by each of its additive terms? I would expect that due to the behavior post supersonic the majority of the lift component is anyway always due to mass displacement while other stuff like the Bernoulli pressure differential is actually just a small component. Am I right/wrong?
Stu
Suddenly the reason why a highly cambered wing is high drag when compared with a less cambered wing with the same cord becomes clear!
I always knew it to be so from experimental data, but now I know why!!
mrluke
mrluke
At the risk of being shot down in flames....
With my old physics hat on I would say that referring to low pressure as causing suction isn't totally accurate. While I understand why it is often referred to that way, in reality its actually the higher pressure pushing in to the low pressure area.
In the same way that if you try to scoop water out of the bath with your hand, the rest of the water rushes to fill the void.
Its a pedantic point but as you are explaining things on a molecular level, feels appropriate.
vorticism
323
jjn9128 wrote:
21 Apr 2022, 16:47
A denizen of Middle Earth ought to know better :D
https://en.wikipedia.org/wiki/Noldor
𓄀
Vyssion
Moderator / Writer
SiLo wrote:
21 Apr 2022, 00:08
It's a really small thing, but the additional drop in pressure that the separation induces just barely eeks out a little more flow acceleration on the suction side of the aerofoil to give it that last little "kick". But it very quickly drops off as the separation front moves forward. It's similar to tyre slip... you actually have "maximum grip" when your tyres are every so slightly slipping. That last little bit of slippage gives you a "kick" in the cornering direction, but too much, and you drastically lose grip.
dialtone wrote:
21 Apr 2022, 19:10
The Navier-Stokes equation solves what happens for a packet of air "in general". If that air packet happens to solve out with a lower pressure, and it is located on the suction side of the aerofoil, then that pressure drop for that packet will "suck" the aerofoil down. But, just as a basic yardstick to use, most lift comes from the pressure term, most drag comes from the pressure term at low speeds and changes to the viscous term at high speeds, and supersonics kind of
Supersonic flow behaves very differently from subsonic flow... In general, a fluid will react to differences in pressure because pressure changes are kind of "how a fluid is told to act". Sound is miniscule fluctuations in pressure and so the way I kind of describe it is "the fastest speed that information can move through a fluid". Usually when fluid hits the front of an object, a stagnation pressure builds up, and then that pressure starts to have an influence upstream of itself (forwards). So basically, the air coming along sort of "knows there's an object up ahead" because of that.
When you are supersonic though, that stagnation pressure upstream effect cannot propogate forwards because "information can't travel that fast in air" (cause you're already moving faster than it's max speed). So when fluid actually reaches the object, the fluid is suddenly forced to change its temperature, density, pressure, and Mach number all at the same time... in an extremely violent and irreversible manner; which is called a "shock wave". So it's kinda "all of the above".
mrluke wrote:
21 Apr 2022, 23:58
You're absolutely correct, and in my little notebooks, it's written that way. This was just written for the masses because it's easier to think of "suction" as a separate entity, instead of "just lower pressure than another point in space" :D
#aerosaruman
SiLo
135
Vyssion wrote:
22 Apr 2022, 13:16
SiLo wrote:
21 Apr 2022, 00:08
I remember Mercedes regularly having that exact separation on their rear wing a few years ago, and always thought it was a less efficient wing than others that shower attached flow along the entire chord. So this explains those decisions! If I can remember which car it was I'll find the pictures.
Felipe Baby!
Hutchie.91
Hutchie.91
Vyssion wrote:
20 Apr 2022, 23:25
Forgive me if you've already explained this earlier, but isn't the cause for generating lift or downforce from the conservation of momentum, Newton's Third Law and arguably just as important but often never gets mentioned, is the Kutta condition and the circulation around the aerofoil this creates? Again, sorry if you have already explained that, I just scanned through your post since its nearly 4am. It also doesn't help that when it comes to aero, im just a pleb with a Mechanical & Automotive degree so my aerodynamics knowledge isn't too deep and already pretty niche.
Definitely will give this a proper read tomorrow as I do enjoy creating my own freeform aerofoil profiles in Catia/NX.
hollus
The way I see it, the conservation of momentum and Newton's third have never caused anything. They are how the universe works, they help make understandable explanations, but in a way, when something something causes a move (a partial vacuum over there), they kick in a fraction of time later. As a reaction, not as the initial action trigger.
Isn't Kutta also simply the conservation of momentum manifesting itself? The circulation does not cause the lift, but lift generation comes, unavoidably, with circulation. IMO.
But it is probably all hen and chicken anyways. Especially since "that vaccuum over there" does not really exist, it is just less pressure then over here, same way as cold doesn't exist, it is just less heat.
