johnny comelately
johnny comelately
110
J.A.W. wrote:
27 Apr 2022, 09:49
2023 iteration of Rotax/BRP/Ski-Doo 850 snowmobile, 180hp with (altitude compensation) turbo.
https://sledmagazine.com/ski-doo-pushes ... c-turbo-r/
This is a good expose of that little gem too:
vorticism
323
J.A.W. wrote:
27 Apr 2022, 09:49
The expansion chamber ahead of the turbine reminds me of Merc's exhaust headers.
𓄀
johnny comelately
johnny comelately
110
This may interest you then. As an example of some current 4 stroke MX ideas.
gruntguru
gruntguru
564
Stepped header primaries are becoming very common but the use on a turbo application is curious.
vorticism
323
Helps evacuate the cylinder just as in a two stroke. Helps reduce power required for exhaust stroke. Also advantageous during wastegate open regime.
𓄀
J.A.W.
J.A.W.
109
gruntguru wrote:
29 Apr 2022, 00:08
The Rotax/BRP/Ski-Doo 850 turbo has a 'Y' junction 2-into-1 header, & the attached expansion
chamber/diffuser cone pipe - has to be gas-pressure sealed - yet not fracture prone.
gruntguru
gruntguru
564
Ahh interesting, thanks J.A.W. Does that layout (with or without turbo) function the same as one chamber per cylinder in terms of expansion chamber "supercharging".
J.A.W.
J.A.W.
109
gruntguru wrote:
29 Apr 2022, 00:31
With a 180 degree crankshaft 2-stroke, firing intervals allow for this expedient, but packaging/costs
trump max output/efficiency gains ultimately shown by running individual systems per cylinder.
A larger number of cylinders will allow closer combustion events & synergistic flows accordingly as
gas flow can be timed as continuous, or over-lapping (3 cyl 2-strokes = 6 cyl 4-strokes, pulse-wise).
gruntguru
gruntguru
564
. . and of course wave supercharging becomes less important when you have a hair-dryer hanging off the side.
johnny comelately
johnny comelately
110
I always understood the step is to prevent the pressure wave going back into the engine.
We have used reverse cones with some success to achieve same .
gruntguru
gruntguru
564
The two stroke "pipe" is designed for the pressure pulse to go back into the engine (the pulse contains fresh charge not exhaust gas).
johnny comelately
johnny comelately
110
gruntguru wrote:
29 Apr 2022, 06:33
I meant the step on the 4 stroke pipes, a la F1 (at least the older NA ones), NASCAR etc
J.A.W.
J.A.W.
109
gruntguru wrote:
29 Apr 2022, 05:46
That's a bit of a 'curly one' gg, if its natural vs perm, (& don't get us started on H-peroxide additives)..
vorticism
323
gruntguru wrote:
29 Apr 2022, 05:46
This would depend on the differential pressure between cylinder and turbine inlet. I assume never as extreme as venting to atmosphere directly, perhaps unless during WGO. Regardless, wave tuning should still be possible, pipe enlargement will lead to a pressure and velocity drop locally. Same for the 'supercharging' wave, maybe there is a small gain to minimizing crossflow beyond what is needed. Less compressor work.
𓄀
Pinger
Pinger
From this:
To this:
No mention of why the turbo was relocated to the end of the pipe.
