McMrocks, Good post...
McMrocks wrote:... the connection between floor and chassis ( the bar from the front of the floor to the tube) is not very aerodynamicaly shaped. I can't imagine RB sacrifices this for no good reason. And it could be also made off carbon fibre but it isn't
Many moons ago, discussing stability issues experienced with the Lotus 80, I suggested it might be possible to control downforce by "gearing" the leading edges of the tunnels to the suspension, much in the way
geared tabs are used to modify hinge moments in aircraft controls. The idea was vetoed at the time as being (too obviously) illegal. I wonder....If it is possible to control suspension ride heights with hydraulic coupling, why not also the splitter?
