The basis for my question is that they still use a Pneumatic valve system in F1, if I am wrong in this assumption, forgive me but I'll contine
Camless Pnematic valve trains should be banned in my opinion because this would change the face of racing in F1. I would ban all cam systems not adaptable to the modern petrol or diesel engine. This would mean you could use traditional cams but they would be forced at the same time to put more research into electromagnetic valve actuation systems like those prototyped by Lotus Engineering. Electromagnetic valve actuation needs to be researched more and motorsport is the best place to do it. But in the mean time the engines could use a dohc system with cam wheels.
This would have several effects -
lower engine speeds
CoG raised
weight gain?
better reliability
reduced fuel consumption
reduced corner speeds
a drag race in the tow of another car should be long enough for the tow to give a real help to the chasing car instead of them blatting down the straights at lightspeed
Unit price of each engine should be lower.
A major con is the initial cost of the redesign but they would be designing a new engine anyway, so it shouldn't be that much of an issue.
The other one is that the rich teams will plough more money into the electromagnetic/solenoid systems but this should/would benefit jo public in the long run. An argument can be made for this opening F1 up to increased cost, but it's worth it in my opinion and change always costs.
This change alone would see more research in cam/valverain design, it would slow the cars down and if they build them properly reduce engine failure's due to the cam system (though I recognise when you're pushing the limits then things break).
I only though about this at the weekend but wondered what you all thought of this. Am I barking up the wrong tree in the wrong field? Or should I run for President of the FIA
Regards
