Scuderia Ferrari SF16-H
f300v10
f300v10
185
Re: Scuderia Ferrari SF16-H
giantfan10 wrote:
Was quoted somewhere that they were bringing new sidepods and there is also a new rear wing they didnt run in sochi that they may run here... diffuser is also said to be new.
Sidepods are said to weigh less than the previous version
The report of the new sidepods and diffusor were from Bild.de, not what I would call a regular source of F1 tech news:
http://www.bild.de/sport/motorsport/seb ... .bild.html
So I don't put to much faith that these parts will appear on the car. Also no similar info at this point from more reliable F1 sources, like AMUS or Autosport.
Der_Meister45
Der_Meister45
In the expanded view it looks new, I don't ever remember seeing that opening or whatever it is on the floor behind the barge board before. But that area is very under photographed so its hard to tell
Nice Picture of the Diffusor.
f300v10
f300v10
185
New rear wing. Endplates look to be the same. More camber in the mainplane, and steeper AOA on the upper flap. The new wing is being used with the monkey seat, the old without. The more aggressive nature of the new wing may need the influence of the monkey seat to prevent stall. The leading edge of the upper flap on the new wing appears to have a slight upward curvature in the center, mirroring the leading edge of the mainplane.
Comparison with Vettel (new) and Kimi (old), the changes are subtle :
Another comparison:
f1316
f1316
84
Brake ducts on the above look slightly different.
Are they both running new sidepods? Tough to see but they look like they're running the same as each other
f300v10
f300v10
185
f1316 wrote:Brake ducts on the above look slightly different.
I haven't seen any indication of new sidepods, or diffusor being used at this point. Just the monkey seat, and new rear wing.
ferkan
ferkan
31
Asymmetrical break ducts on Ferrari as well.
Silent Storm
Silent Storm
111
Ferrari PU in SF16-H.
Have they reverted from the innovative sidepod from SF15-T to a more conventional one in this car.
The cheapest sort of pride is national pride, every miserable fool who has nothing at all of which he can be proud adopts, as a last resource, pride in the nation to which he belongs; thus reimbursing himself for his own inferiority.
F1NAC
172
Too much space for this years bodywork
ferkan
ferkan
31
Ferrari has new smaller radiator inlets in Barcelona it seems.
New inlet (Barcelona)
Old inlet (Sochi)
Chuckjr
37
Wow dramatic decrease in size I'd say. :shock: =D> =D> =D>
Watching F1 since 1986.
Turns out Bild got it right lol.
I kept looking for a more aggressive slope, something like the SF15T Barcelona and didn't notice this.
giantfan10
giantfan10
27
New sidepods CHECK!!
New rear wing CHECK!!
New Diffuser CHECK!!
:D
ferkan
ferkan
31
Silent Storm wrote:Ferrari PU in SF16-H.
https://pbs.twimg.com/media/CiRjl9eWsAABofN.jpg:large
Also, radiators are V design this season. Ferrari had that in F2005.
f300v10
f300v10
185
giantfan10 wrote:
f300v10 wrote:
giantfan10 wrote: Was quoted somewhere that they were bringing new sidepods and there is also a new rear wing they didnt run in sochi that they may run here... diffuser is also said to be new.
:D
I will give you the sidepod inlets, but see no evidence of any change to the diffusor.
