I remember Leo Turrini saying they wanted more aggressive nose, but it couldn't pass crash test (F1AT reported the same).
But wouldn't they be able to just put less aggressive nose like current one, and then work on another until it passes the crash test? It shouldn't require change in aero concept or bodywork, right? I mean, Williams introduced new on in Bahrain and RB has done so last year, so Ferrari should be able to as well. If they have problem with it, then they simply can't hope for championship when few other teams simply do better job. Also, RBs nose pylons are extremely thin as well, it simply looks staggering good tbh.
BTW difference between RBs and Ferrari wishbones are at least double in size (vertical), do they need to reinforce them with more material since its not strong or stiff enough, and RB has a know how with lighter and thinner material that is sufficiently stiff? It just looks like massive difference, unless it accounts to very little.
EDIT
I saw you posted Ferrari testing Pirellis for 2017 car next month. Maybe they started with next years car early...Maybe that wind tunnel loophole was used mostly for 2017 car models and philosophies? Who knows, would be interesting for Ferrari to bluff Merc with this years car, and actually using that wt time for 2017 car.
