How will teams handle V6 imbalance?
ChipAyten
ChipAyten
With the new regulations and a switch to T-V6 engines I've been pondering this. As I'm sure most gear-heads around here know V6 engines (both 90 and 120degs) are plagued with harmonic imbalance. Due mainly in part to 2 pistons firing on one side with just 1 on the other and vice versa. What are some ways teams can counteract this? The effect is less and less prevalent as RPMs increase so it may not even be much of an issue, but i doubt that.
Tim.Wright
330
Re: How will teams handle V6 imbalance?
I'm not an engine man, but I imagine they will just live with it. Its the nature of the beast and the same for everyone. Ride comfort is not important and I don't think it saps any performance.
It was the same when they switched from V10 to V8. The drivers remarked they vibrate a lot more, but so what?
Apart from making joints and bolted interfaces a bit more vibration resistent i don't think there is anything extra to do.
Tim
622
are we sure that they will be 90 deg ?
why ?
(in the previous turbo era the 90 deg designs happened by conversion of road engines that were originally V8s)
120 deg is the engine man's choice anyway
60 deg seems logical today ?
Saribro
Saribro
Tommy Cookers wrote:are we sure that they will be 90 deg ?
why ?
Rules..
622
the vibration won't be as bad as current engines
the 2014s will be effectively (or nearly) 3 90 deg V twins (current F1 is effectively/nearly 4 90 deg V twins)
the only/main imbalance of either is at twice engine frequency and tolerably low magnitude (as an inline 4)
(the 2014 engines will be run at about 12000 rpm (not the current 18000 rpm) the vibration force will be roughly half those current)
strad
117
Odd fire vs even fire
Sir Stirling Moss
622
IMO the vibration is caused by the (out of balance components of) inertia forces
the 90 deg V6 has less uneveness of combustion forces than does eg the traditional 60 or 65 deg V6
this helps the crankshaft design (to be better than the 60deg), but is not the true even firing of the 120 deg V6
spacing of inertia forces is of course related to spacing of combustion forces and is more important at F1 rpm
but at the 2014 12000 rpm some uneveness is less important (than at current 18000 rpm)
ChipAyten
ChipAyten
Interesting after I write this I read a report of Bernie not liking the prototype V6 engines because they dont sound right. Perhaps he'll scrap the whole thing and advertisers will realize F1's contribution to global warming is negligible, and the advancements born out of what is essentially a R&D competition far outweighs the small amount of carbon it pumps into the air? Fat chance. :roll:
Jersey Tom
Jersey Tom
Probably handle it the same way they did with much more powerful V6's in the 80's
xxChrisxx
xxChrisxx
44
Tim.Wright wrote:I'm not an engine man, but I imagine they will just live with it. Its the nature of the beast and the same for everyone. Ride comfort is not important and I don't think it saps any performance.
Tim
You might not be, but that is pretty much spot on. If it doesn't cause durability problems they will do nothing.
piast9
piast9
How about a balancer shaft? The overall weight of the F1 engine forced by the rules is much higher than manufactures are able to achieve. So it should be easy possible to make the engine a bit lighter and add the balancer shaft to cancel vibrations.
langwadt
langwadt
ChipAyten wrote:With the new regulations and a switch to T-V6 engines I've been pondering this. As I'm sure most gear-heads around here know V6 engines (both 90 and 120degs) are plagued with harmonic imbalance. Due mainly in part to 2 pistons firing on one side with just 1 on the other and vice versa. What are some ways teams can counteract this? The effect is less and less prevalent as RPMs increase so it may not even be much of an issue, but i doubt that.
flat plane V8s are not balanced either, cross plane is better balanced but you'd need a crazy exhaust like on the old GT40
aussiegman
aussiegman
105
Due to its shorter block length a V6 casing is typically a more rigid element for a given weight than a V8 or V10 while the shorter crankshaft is also less susceptible to torsional vibrations and flex. As a stressed member of the chassis (this is important to remember), this is critical as there are fewer isolation options to prevent harmonic transfer and propagation into the various systems like suspension and chassis. All these things allow it to be either lighter in the first instance or able to cope with the imbalances better for a similar components construction.
It can and does take power and if not accounted for will dramatically affect reliability. However as above a V6 is generally torsionally stronger and the further reduction of RPM’s, with Renault saying that 12,500rpm is likely to be the limit due to fuel flow restrictions, would certainly help promote longevity as the 2nd order harmonics from net component speed imbalances through each period of crankshaft rotation is substantially reduced.
It’s also a consideration that vibrations from the engine can prematurely fatigue other components attached to it so a decision based on weight, longevity, packaging and serviceability would need to be made, as well as the FIA requirements for part longevity. A high degree of vibration from the engine can very easily fatigue gearbox casings, gearsets, driveshaft components, engine ancillaries (think Renault alternators as an example) or carbon constructions (fatiguing the layups) leading to premature wear and failure. So do you increase sizing and weight of the drivetrain/chassis/components or fix the inherent issue at the source??
This is a major issue as the vibration is generated by the non-symmetrical movement of the piston/rod assemblies throughout each crankshaft rotational period of 720°. Descending rods are moving at differing speeds through their rotation in relation to ascending assemblies (particularly at angles either side and at TDC and BDC), causing a net vertical imbalance twice each crankshaft revolution. Increases in stroke will give rise to a greater difference in these speeds and accelerations because of increased distance traveled. Increases in bore “CAN” result in an increase in mass (of the piston and rod assembly) which increases inertial forces and hence increase the imbalance again.
The biggest reason these need to be carefully considered is the amplitude of these harmonics, which due to the non-symmetrical movement at twice RPM's increases quadratically (x4) as RPM increase, no matter how well balanced the completed bottom end assembly is. As it is an asymmetry (distance vs. speed through crankshaft period) and not weight imbalance that causes the issue, balancing won't negate the problem.
Tim.Wright wrote:Apart from making joints and bolted interfaces a bit more vibration resistent i don't think there is anything extra to do.
2nd order harmonics (vibration) due to the above will need to be considered and rather than resistant I think isolation and insulation from the harmonics may be the path taken for various reasons.
Tommy Cookers wrote:IMO the vibration is caused by the (out of balance components of) inertia forces
Do you mean weight out of balance or movement out of balance??
AFAIK, there are two primary types of vibrations or harmonics in an engine. Rotational torque oscillations which are caused due to imbalances in the firing order and 2nd order harmonics that occur due to velocity differentials of the various piston rod assemblies in motion. Component balance is typically a minor, very well understood issue and easily overcome during engine construction.
Tommy Cookers wrote:the 90 deg V6 has less uneveness of combustion forces than does eg the traditional 60 or 65 deg V6
Are you simply talking about the firing order per degrees of revolution due to spacing on the crank of the journals or something else??
I was always told that the 60° angle is the most efficient from a minimization of harmonics and vibrations due to torsional and rotational imbalances for a V6. Nissan had the VQ series which were all 60° V6’s as well as the new VR38DETT GTR engine which uses a 60° V6. Ford with their various designs up to the recent Duratec V6 were more often than not 60° (Essex and Cologne IIRC). Then there is the ubiquitous Alfa V6 which was a 60° design also.
Tommy Cookers wrote:this helps the crankshaft design (to be better than the 60deg), but is not the true even firing of the 120 deg V6
90° V6’s typically see “more” vibrations/harmonics than a 60° V6’s which (I thought) was generally considered the most efficient V6 angle. Most 60 deg V6’s have been able to do away with balance shafts by using 120 deg, 6 throw cranks phasing cylinder pairs together, however some use 3 throw cranks with smaller counterweights or “flying arms” (no idea why they are called this) and balance shafts.
There is also the use of 30° split pin cranks which Mercedes particularly is fond of and modern manufacturing and metallurgy could make this a viable alternative if allowed under the rules.
Tommy Cookers wrote:spacing of inertia forces is of course related to spacing of combustion forces and is more important at F1 rpm
Absolutely. The torsional oscillations of the crank due what I expect to be a 120 degree firing order and the 2nd order harmonics from net component speed imbalances of the rotational assemblies are both going be greatly reduced and less of an issue with RPM’s coming down from 18,000rpm to 12,000/12,500rpm expected. It’s another reason (other than restricted fuel flow) expectations of the 15,000rpm limit rarely if even being used.
piast9 wrote:How about a balancer shaft? The overall weight of the F1 engine forced by the rules is much higher than manufactures are able to achieve. So it should be easy possible to make the engine a bit lighter and add the balancer shaft to cancel vibrations.
Increasing rotating mass, complexity, serviceability and the parasitic drag mean that the engineers will likely look to other ways of reducing and negating the effects of imbalance harmonics.
Driving a counter rotating mass damper assembly can take a noticeable amount of torque from the engine which might end up in a Mercedes vs. Renault straight line power/speed difference, especially as fuel flow is limited they’ll be looking for max power out of the engine for the limited fuel flow allowed I would expect. Its all about efficiency gains for 2014.
Never approach a Bull from the front, a Horse from the back, or an Idiot from any direction
Greg Locock
Greg Locock
233
aussiegman wrote:It can and does take power and if not accounted for will dramatically affect reliability.
Um, so you think a balanced engine will develop measurably more power than a less balanced one of the same configuration? There are some second order (hah) effects that come into play but gut feel says they are unmeasurable. The rest is just accelerating and decelerating inertias which won't affect the output torque.
So far as TVs go, it is unusal to see more than about 2 degrees peak to peak on a production engine, which is such a tiny effect that it doesn't affect torque, although I suppose a racing engine might see more TV than that and so might see more spark scatter, whic might affect the output.
aussiegman
aussiegman
105
Yep, from my practical experience and theoretical understanding, "a balanced engine will develop measurably more power than a less balanced one of the same configuration".
However lets qualify that and not start splitting hairs.
A "measurable" difference is one that can be measured and I would agree (if what you are actually saying is) the difference in power won't be a huge differential in % terms of the overall output of the engine. But i also never said it would be.
I fully understand the difference isn't going to be huge orders of magnitude greater, however F1 engineers are chasing maximum efficiency, especially with fuel restrictions in place and longevity requirements due to FIA engine restrictions.
So a 5hp drop might be only 1% of total engine power, but it should be measurable on an engine dyno in a proper test cell with repeatable conditions like engine manufacturers have access to and it maybe significant if it is at the right spot in the RPM range and effectively "free power".
So, where an engine has an imbalance due to variations in the rotating assembly weights on a per cylinder basis, then energy is lost through the imbalance which is seen as energy lost to harmonics and other effects.
The First Law of Thermodynamics (conservation of energy) means that the energy to produce anything such as sound (harmonics), kinetic movement (vibrations) or heat (self explanatory) needs to come from somewhere and so derived from part of the systems total exergy and channeled in to other systems unable to be utilised to do work.
So huge power differentials won't be seen which I indicated if poorly qualified with "it can and does take power".
I assumed it was know that the number wasn't going to be huge % but noticeable and maybe should have said:
"it can and does take some measurable amount of power"
The substantial affect is on reliability and "if not accounted for will dramatically affect reliability" of the engine and that can and is a problem.
